Key Code
Old Jun 9, 2014 | 02:50 PM
Gradyboi78's Avatar
Key Code
Is there anyway possible I can get a key code to have a key cut for my 05 infiniti with smart key? My nearest dealer is over an hour away.
Old Jun 9, 2014 | 06:23 PM
05_SkylineSedan's Avatar
20 Year Member
If you're talking about the physical key inside the fob there is a tiny metal tag that came with the original set of keys which has the code on it, maybe 4 or 5 numbers (I can't remember). Presumably if you had that number you could order a precut key. But I'm not sure.
Old Jun 10, 2014 | 12:27 PM
Mustang5L5's Avatar
Only way is through the dealer. I doubt they would give you this info over the phone otherwise I'd just walk up to the nearest Porsche 911 I see and grab the vin and ask a Porsche Dealer.
Call up a dealer and ask, but more than likely you will have to take a ride to the dealer.
Old Jun 11, 2014 | 04:31 PM
Gradyboi78's Avatar
I got it from Grubbs Infiniti by faxing proof I was the ownering of the car. However, I thought by taking out the chip out of my other key and putting in my new key that the key will be able to start the car but it doesn't. Can you not use the old chip with the new key?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
G35xdriver04
Nov 7, 2015 08:31 PM
MThawkins86
Oct 24, 2015 02:07 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
