clicking noise
Old Aug 21, 2014 | 05:00 PM
ADAMEE3's Avatar
Question clicking noise
So im kinda stuck. i recently bought a 2003 g35 sedan. runs great but at speeds above 55 mph there is a clicking and clacking noise coming from my drivers side. its not loud but sounds like something is ratteling around or loose. i cannot see anything under that is loose. i hear it from the corner left of the break pedal. anyone have any idea what it could be? i thhought maybe it was the bumper because it was a ittle loose and i no longer have a shield underneath as well. but im not sure. i tightened the bumper cover to be safe but still makes noise.
Old Aug 21, 2014 | 05:33 PM
5150DS's Avatar
Check the wheel wheel well liner. Or maybe wheel bearings.
Old Oct 7, 2014 | 10:57 AM
trodder's Avatar
could be wheel bearing or CV joint. Check to see if the cv boot is ripped or torn or anything. Does it make a sound when you turn quick in either direction? Checking wheel bearings is easy just get the tire off the ground and grab the top and bottom of the wheel and wiggle it and see if there is any play or clicking/clanking sound when you wiggle it. If your CV boot is torn probably a CV joint issue.
Old Oct 7, 2014 | 11:23 AM
Mustang5L5's Avatar
Wheel bearing, brake component or CV axle
Def get that wheel off and peek around in there and find out, because if something fails at speed, it's not gonna be fun.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
