creaking sound
Jun 24, 2014 | 11:21 PM
Hey guys I have a 03 sedan all stock suspension and when I pull into driveways I hear a creaking sound from the front and rear and suggestions what it might be ?
Reply 0
Jun 25, 2014 | 04:36 AM
your bushings, it's a common problem with g35 models. i'm going through the same thing
Reply 0
Jun 28, 2014 | 02:33 AM
Do you know which ones they are ??
Reply 0
Jun 29, 2014 | 12:00 PM
Is your car lowered? If so your sway bar is now preloaded more than it would be at stock height. This can cause sqweeking in the sway bar bushings and/or sway bar end links. I dropped my car and immediately had sqweeking. I replaced the sway bar bushings with poly bushings an added whiteline sway bar end links. No more sqweeking!
Reply 0
Jun 29, 2014 | 05:51 PM
Yeah i got the same problem with my 06 g started around 60k miles. Anyone know if this will cause problems? Is it worth the cost to fix?
Reply 0
Jul 3, 2014 | 09:19 AM
It is the compression rod bushings. That is the arm on the front that looks like a boomerang. The bushings run 90 bucks for the pair. They have to be pressed in and out.
Reply 0
Jul 7, 2014 | 01:50 AM
Search next time Broski
Reply 0
Oct 7, 2014 | 03:17 PM
I would bet money its your sway bar links that need to be replaced. you can test by unbolting one side of each link in the rear and then bounce on the car and see if its gone. Then if you really think its the front too you can do the same up front.
Reply 0
Oct 7, 2014 | 03:29 PM
basically, you need to figure out which ones are causing the noise. We can list off probables, but without seeing the car in person, we are guessing
Reply 0
