M45 Sport shift knob install...revisited
Old Oct 10, 2014 | 10:49 PM
The Fixer's Avatar
Coming along nicely, thanx for the update!
Old Oct 10, 2014 | 11:09 PM
Mustang5L5's Avatar
Ok, so i jumped the gun a bit. Couldn't wait to work on it a bit after work today.
SInce i wanted the shift **** to click into the boot like OEM, i ordered an M35/45 shifter assembly off Ebay. Cost me $50. Oh well. G37 shift boot rings will work too and are cheaper.
ANyway, i took my shifter bezel out and removed the G35 shift boot. I also broke down the M35/45 shift boot to this.
Not hard to do, not going to explain it all. Plenty of threads on how to remove the 05-06 shifter bezel and removing the boot after that is pretty easy.
Anyway, i swapped the trim rings out. Basically flip the boot inside out and remove the little snap ring. The M35/45 ring is bigger, so it fits tight on the boot, but it goes on fine. A little tricky but took me 5 mins to do. Not a huge deal really. I posted a link with a few shots of these steps earlier in this thread.
But here's the result. The M45 **** snaps into the boot like OEM.
Teaser shot with the M45 **** and shift boot ring.
Anyway, all that's left to do is dremel the new slots for the snap ring to lock the **** in place. I should have that taken care off over the weekend. After that, i'll adjust the white pin's height and report back a number that works best. I'm also probably going to have to put a few wraps of electrical tape around the metal shifter lever. Seems the G35 lever is slightly smaller in diameter than what is on the M45, so the **** rocks a bit. I figure some bands of tape will reduce/eliminate this. Easier than machining a spacer.
Almost done.
Old Oct 13, 2014 | 02:44 PM
Mustang5L5's Avatar
Haven't wrapped this up yet. Still trying to get my hands on a battery powered dremel or find somewhere I can drive with power nearby.
Will give my update as to how I finished.
Finished product shot is same as above. I'll just add pic of notches when I do it.
Old Oct 14, 2014 | 12:21 PM
Mustang5L5's Avatar
Haven't cut the notches yet, but I am driving around with the ****. Just need to hold it down when you shift gears. I'm just waiting to get the proper tool before I finish. I don't want to hack this up.
Anyway. These still count as finished shots because the remaining work is under the boot
Old Oct 14, 2014 | 12:26 PM
Mustang5L5's Avatar
My Component parts list:
M45 sport **** (black leather with white stitching): 34910-EJ70A
Shifter Pin: 34951-1LA0A
M35/45 shift boot top trim ring: Ebay/Boneyard (Or use 07+ G35/G37 shifter trim ring)
Modified shifter pin by drilling out with 7/32" drill bit, and then installing on shifter height so that the pin protrudes 25mm above the black metal shifter lever.
Slide **** onto shaft and mark where new clip will latch onto black shifter lever. Carefully cut slot to that clip will lock into place and hold the ****.
Old Oct 14, 2014 | 09:49 PM
The Fixer's Avatar
That looks sick! So, no more button to depress? Just push down on the **** and it'll activate the release to switch gears?
Old Oct 15, 2014 | 07:47 AM
Mustang5L5's Avatar
No not exactly. There is a button just like stock.
But since I am lazy and haven't dremeled the two slots to actually secure the shift **** to the lever, i'm forced to press down on the **** and then depress the lever.
Basically I'm not done, but posted finished pics. I figure why wait.
Still need to detail out the final steps. I'll get to it perhaps tonight. I'm just a busy guy.
Old Oct 15, 2014 | 08:27 PM
Mustang5L5's Avatar
Ok, so I wrapped this up tonight. Was pretty easy.
I used a sharp pick to mark where I needed to make my cuts. Basically the shift **** bottoms out on the top of the black metal lever. Simply press the **** down fully, and make your marks. Then remove the **** and cut. I used a hacksaw blade in my hand to make the cut. Was pretty easy.
I removed the shifter bezel to avoid damage.
I simply made the cuts on both sides, and tried the ****. I kept going until I could no longer pull the **** off by hand and needed to remove the clip, like the OEM ****. You def do not want to cut high here, or the **** will rock. Measure 4 times, cut once.
Once the **** is on, you'll notice it wiggles a little bit. Simple solution was a wrap of tape about and below the cuts. This took up the slack and make the **** "tight"
Other than that...that's it. The only non-stock thing about the **** is that it twists along the axis about 5 degrees or so. Not bad, but I think i can fix it by adding some material in the slit where the **** rides down. Doesn't bother me enough to worry about now.
But works great, feels great and looks nice! FInished pics are pretty much the same as above.
Picture Share
Feb 4, 2018 12:41 PM
AJC128
Nov 1, 2015 11:55 AM
dseet
Oct 11, 2015 12:40 AM
blnewt
Sep 25, 2015 01:48 PM
