Cam shaft sensor po304 cod bank 1
Old Oct 28, 2014 | 07:56 PM
Chris80's Avatar
Anyone have any information on changing this ? I have a 05 G35. Anyone in Chicago want to help me change it ?? Let me know
Old Oct 28, 2014 | 08:41 PM
bluedevils95's Avatar
Old Oct 29, 2014 | 09:33 PM
TurTLe*'s Avatar
Where in chicago are you?
PM me location.
Also, P0304 is a misfire on 4. Not sure where you get camshaft sensor from.
Old Oct 29, 2014 | 10:42 PM
Chris80's Avatar
Check your messages bro
Old Oct 31, 2014 | 03:48 AM
epborden's Avatar
You can get the sensors from any auto parts retailer like AutoZone, Advance, O'Reilly's, etc. They are super easy to change. The worst problem you'll have is the space can be quite tight so you might have to work your wrench a small bit at a time to get it out, but once it is out it is out and you can pop the new one in.
Old Nov 11, 2014 | 09:25 AM
SNOMAX's Avatar
I just changed both Camshaft position sensors and here's my words of wisdom:
1) Buy Nissan sensors, I bought a Delphi and a Hitachi and both threw the same error codes after 2 days. Nissan sensors worked flawlessly.
2) Replace both banks at the same time. Its expensive, but trust me.
3) Easy install. Do this:
a) Remove the engine cover
b) Access the passenger side sensor from the top/side
c) Access the driver side with a socket and shallow 10mm from behind the engine, leaning over the passenger fender (no need to remove anything but the engine cover.
d) remove the 10mm bolt first, then pull it and the wire connector (pigtail) out of the engine
e) Then push on the connector to remove the sensor.
4) Reinstall.
a) coat new sensor o-ring with engine oil and push into engine block.
b) insert and tighten 10mm bolt
c) reconnect connector/plug/pigtail/ whatever you want to call it.
5) Clear ECU/ SES codes.
Hope that helps.
Old Nov 11, 2014 | 03:02 PM
Dr.Bora's Avatar
what that vide doesnt show you is how to get that sensor off the damn connector. i had to use a wire pic and some wrestling with it to get the connector off
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
