replacing radiator, please help
Old Jan 1, 2015 | 08:16 AM
alwaysaproblem's Avatar
i drive a 2003 g35 sedan(earlier model) i am replacing a cracked radiator. i have looked through and found a few threads on it and it seemed pretty easy.. even with a clutch fan the instructions seemed a breeze. and everyone else said it was a breeze. well **** no it aint(for me at least).
with the clutch fan in the way it is very hard to reach the 14mm bolt for the alternator/powersteering pulley. ( the one you have to loosen before you loosen the tension bolt below to remove the belt that way I am able to remove the fan clutch so i can get to the radiator...im pretty sure ) when i did first attempt to loosen i, and idk if it was already stripped before but it slid on the bolt and it sure as hell is stripped now. is there anything i can do about this? am i done now? is it time for the dealer to replace my radiator and let them deal with it? can i remove the radiator from the front by remove the front bumper and radiator support?
And this might be in the wrong area
im also pretty new to cars and i only know so much so correct me if im wrong or tell me something i missed please.
here are some of the pictures of my problem.
please offer a thought
Old Jan 1, 2015 | 10:00 AM
eazdaskeez's Avatar
You don't have to remove that fan, well I didn't. I removed the housing around it and lowered the radiator through the bottom.
Old Jan 1, 2015 | 03:45 PM
thanks a lot for your reply. i knew someone could help my dumb *** out. after reading this i went and tried it and it was pretty damn easy. no one else said anything about going from under the car and removing if there.. you're gunna need to car raised a bit but it was easy. thanks a lot.
minus the fact that when i was removing the trans hoses on the bottom of the rad, one of the nipples or whatever they're called broke off inside the hose as i was pulling it out... thankfully i was able to pull it out with pliers(after spilling enough trans fluid to where i have to now check and most likely refill)
KevinnnVo
Oct 14, 2024 04:33 PM
tiguy99
Mar 1, 2016 11:42 AM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
