Tps
Old Jan 1, 2015 | 02:00 PM
Moe_AW's Avatar
Tps
Hello,
I just changed my throttle position sensor and programed it. The car drives just fine but the rpm is a little high. When the gear is on P or N the RPM would be 2 dots above 1 and if the gear is on D the RPM would be 1 dot under 1. I really don't know what happened. I hope some one could help.
Old Jan 1, 2015 | 10:13 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
From https://g35driver.com/forums/g35-cou...-question.html
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch to “ON”.
3. Turn ignition switch to “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock. 1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that the accelerator pedal is fully released, then turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Mr. Wonderful
Jun 16, 2006 02:42 PM
Sportcoupe35
Jun 7, 2006 12:54 PM
TheKnite
Feb 14, 2006 05:45 PM
gettaluvr
Sep 11, 2005 03:31 PM
neffster
Jun 1, 2005 02:24 PM
