Weird explosion in my car!
Old Mar 1, 2015 | 12:12 AM
ImJJames's Avatar
Angry Weird explosion in my car!
This morning I start my car as usual and it started just fine. As soon as I start to move the car a weird noise like a live high voltage wire contacting metal started to go off and bam something exploded under my car. I get out of my car and check under and I see all these pieces scattered under my car!
This was so weird to me I honestly thought maybe I just ran it over. So I continued to drive the car and everything seemed to be working fine. I only drove it for around 10 minutes to drop someone off. Tonight I tried starting the car again but this time the same exact noise(like a open high voltage wire contacting metal) started to go off when I try to start car. I got scared so I will be leaving it alone for now.
I feel like my car is rigged with a bomb... what the **** is going on?
EDIT: User Hatchman was on point!!! Starter exploded taking out transmission housing with it!
Old Mar 1, 2015 | 12:45 AM
DigitalDeviant's Avatar
Time for a new starter.
Old Mar 1, 2015 | 12:56 AM
ImJJames's Avatar
Interesting. How exactly does half a inch of steel explode in little pieces in a car.
Old Mar 1, 2015 | 09:51 AM
TurTLe*'s Avatar
Well have you ever tried to hand turn a motor... your starter does that in a matter of miliseconds.
That long bolt does look like a starter bolt to me...
Old Mar 1, 2015 | 10:40 AM
Hatchman's Avatar
Starter exploded, took some of the transmission bell housing and other brackets with it.
The starter has one of the highest voltage wires going to it, and it has to turn your entire motor to start it, so it throws out some torque.
My guess, one of you starter bolts backed out, starter was on a little crooked, started eating itself, broke loose the big voltage wire causing that arcing and sparking you are hearing.
At best, you are going to need a new starter, but looks like your transmission housing is gone too... which may require a new tranny or some very good welding to put the housing back together, depending on how bad and how far it cracked the housing. Some trannys you can replace just the bell, when clutches explode, but not on ours.
Good luck... and don't start your car anymore like this. If that starter wire grounds out, it could set your car on fire if the fusible link doesn't save it.
Old Mar 1, 2015 | 11:06 AM
Urbanengineer's Avatar
BECAUSE ITS CAST MOFK!
Some serious torque in the wrong spot lol!
Old Mar 2, 2015 | 07:52 PM
saywat?'s Avatar
damn I thought this **** only happens in cartoons
Old Mar 3, 2015 | 08:41 AM
Mustang5L5's Avatar
If you keep starting the car like that, you will likely damage the flexplate.
You need to get that fixed ASAP, and unfortunately it looks like it did some damage to the mounts. This might be a tough one to fix cheap
Old Mar 3, 2015 | 09:22 AM
Texasscout's Avatar
Hand crank out the front bumper.
Old Mar 3, 2015 | 01:02 PM
ImJJames's Avatar
OP UPDATED WITH NEW PICTURES!
Old Mar 3, 2015 | 03:56 PM
Mustang5L5's Avatar
Yeah....that's not going to be a fun repair.
Old Mar 3, 2015 | 04:09 PM
ImJJames's Avatar
Selling the car as-is. Buying a g35 coupe on thursday.
Old Mar 3, 2015 | 05:04 PM
It would be pretty shitty not to disclose that.
Old Mar 3, 2015 | 05:07 PM
saywat?'s Avatar
buyers tries to start it and cant. seller says "jus needs a tune up" lol
Old Mar 3, 2015 | 09:16 PM
markc's Avatar
Yup, a tune up, and a starter. Oh yea, and a tranny.
