04 sedan with obd 2 code P0300 & P0011
Old Mar 26, 2015 | 10:05 PM
ibg's Avatar
ibg
I have a 04 sedan with 180,000 miles.
recently it started to idle a bit out of the ordinary where it feels like its shaking but its not enough where you can notice it if you standing next to it.,.. You need to be in the driver seat.
If i put the car in motion the rattling/shaking goes away and it will come back some times when im in idle.
Ran the scanner on it and it came back with P0300 & P0011
what would be the most common issue on this car ?
btw i already googled it but different car's different solutions.
I am going to check on what is causing the misfire maybe bad plugs or a hole in one of the lines.. Also the fuel filter.
The second code is for valve timing which is the one that worries me
Old Mar 26, 2015 | 11:40 PM
ScraggleRock's Avatar
180k? When's the last time you changed the plugs? People think these cars are impervious to plug changes cuz Infiniti suggests changes at 105k intervals, when that is simply not right. 40k intervals will keep it running at peak performance. This could also be a coil pack issue, or even a head gasket issue. You gotta pull the plugs and check out what's going on in there.
Old Mar 26, 2015 | 11:45 PM
ibg's Avatar
ibg
I bought the car when it already had 135k miles on it ..
Only thing ive done mechanically to it has been regular oil changes.
Im gonna work on it this weekend.
Do you think if the plugs are bad they could aslo be causing the other code where it comes up with valve timing ?
Old Mar 27, 2015 | 07:32 AM
That, I would think, would be a sensor, but tackle them one at a time to be sure.
Old Mar 27, 2015 | 10:14 AM
ibg's Avatar
ibg
Start with the misfire issue or should I start tackling first the valve timing issue ?
Old Mar 27, 2015 | 11:11 AM
Mustang5L5's Avatar
Read this thread.
https://g35driver.com/forums/g35-sed...011-p0300.html
At 180K miles, and no idea if the plugs were changed before, i would at the very least pull out 2-3 plugs and inspect them for wear and replace them.
Old Apr 11, 2015 | 09:58 PM
ibg's Avatar
ibg
so after all this time finally due to work and spending time with the family finally have time to work on my car today.. been using my extra car and miss my G..
Im gonna inspect the spark plugs and see if they need changing but all the research ive done on this issue keep bringing up sensors and valve timing and chains , and oil changes .etc.. dont even know where to go after checking the spark plugs but will see
Old Apr 11, 2015 | 10:17 PM
ibg's Avatar
ibg
Originally Posted by Mustang5L5
Read this thread.
i checked out that thread you linked and i get two different reasons as to what the issue could be
One guy says
Originally Posted by infinitidude
the p0011 code is not for the camshaft position sensor,the p0011 is for your intake valve timing solenoid which is the solenoid with the green connector at the front of each valve cover. This code is normally due to low oil due to the solenoids run off of oil pressure. if the oil level is full then you need to replace the solenoid for whichever bank the p0011 is for. The multi cylinder misfire code can be caused from a dirty mass air flow sensor or something touching the hotwire inside the sensor(a hair or piece of a leaf,etc) Hope this helps
but
Originally Posted by Patriotsfan5660
i got this light when my fan belt broke and it threw 3 different lights including this one and it was the camshaft sensor.. it was the one behind the engine on the passenger side of the car.. a pain in the *** to change but its worth it, unless you wanna pay to get it done. fixed the problem for me, i would start by changing it its only like 50 bucks at autozone.
so what do you think .. valve timing solenoid or camshaft sensor ?
Old Apr 13, 2015 | 09:52 AM
Mustang5L5's Avatar
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/ec.pdf
Page 168 and on. I'd read that and see if that helps troubleshoot.
Old Apr 15, 2015 | 12:39 AM
ibg's Avatar
ibg
so after doing all the research and all the input from you guys.. only thing i changed was the cam shaft sensor bank 1 which is the one on the passenger side.. seems to have done the fix.. bought it at autozone....
Hasanbaloch
Feb 29, 2024 08:45 PM
Ednica87
Sep 5, 2015 02:59 AM
ghost_g35
Aug 7, 2015 10:31 AM
Detailed Image
Jul 29, 2015 08:42 AM
