Brake light in back window is out
Old Jul 12, 2010 | 10:22 PM
eddlove2001's Avatar
back window brake light went out, My 03 g35 sedan didn't come with a manual. I also have 2 kicker 12 beating down the block, could I busted LED panel and where should i start?
Old Jul 12, 2010 | 10:33 PM
Wannabe6MT's Avatar
-MN G Crew-
Wait, what?
Old Jul 12, 2010 | 10:34 PM
thescreensavers's Avatar
Mr.202?
^ I think he has some super woofer in the trunk wondering if that broke it.
nah they go out. I believe 03/04's were not LED's, right?
Old Jul 12, 2010 | 10:37 PM
Wannabe6MT's Avatar
-MN G Crew-
^They were LEDs.
Old Jul 12, 2010 | 11:01 PM
yeah, its a led panel, didn't want 2 go 2 the dealership. I have 2 12" kickers CVR, replaced interior speakers as well, dynomat, great sound quality, but I do think it is 2 loud sometimes.
Any item of cost to replace led brake strip or diy?
Old Jul 13, 2010 | 02:17 AM
Heist.'s Avatar
Mine is also out. Pretty sure I read that you should just buy the whole light. TO get to it is a pita. You have to remove the back seats and then all the stuff around the seat belts. Then remove the rear upper tray and then it is only like 2 screws and a plug.
Old Jul 13, 2010 | 02:47 AM
Mr.202?
^ Someone said you can go from the trunk?
idk
Old Jul 13, 2010 | 03:05 AM
Heist.'s Avatar
oh thats a possibility. More I think about it your probably right. Just remove the upper cover on the trunk and remove the two screws and pull it out. I think?
Old Jul 13, 2010 | 06:25 AM
Mustang5L5's Avatar
Common issue. Mine works intermittently. 90% of the time it works but then sometimes I back up near a window and see that it's out.
Most 03/04 I see on the road have it out. Has nothing to dow with your subs
Led panel needs to be replaced, and ita slightly expensive.
Old Jul 13, 2010 | 07:42 AM
could be possibly under recall
check this out
http://www.autobuyguide.com/2003/12-...lls/index.html
Old Jul 13, 2010 | 08:29 AM
Mustang5L5's Avatar
check this out
That is for all the brake lights not working which is a faulty switch on the pedal.
ONLY the 3rd brake light not working is a common issue and not a recall...yet. It should be. Next time you are out and see a G35...check it's brake light. More often than not, it is out...especially on 03/04's
The fault is a diode on the circuit board. it can be replaced if you can get a diode of the same specs (www.mauser.com) and know how to desolder and solder. Possibly a $.50 cent fix after you remove your entire back seat and rear shelf to take it out. Alternative is ~$200 for a new LED strip and install it yourself...
or you can wire in a $10 LED strip and run that. Do some searching, it's a common issue. I've seen a thread showing the diode replacement as well as one installing the cheap strip.
For me...i'm gonna take it out and replace the diode...but i'm trying to find specs first so i can have one on hand ready to go.
Old Jul 13, 2010 | 08:33 AM
Mustang5L5's Avatar
According to this site, it's a 1N4007 rectifying diode avail at radio shack
www.mauser.com sells them for 26 cents each.
http://forums.automotive.com/70/7255...diy/index.html
Old Jul 13, 2010 | 08:52 AM
Wannabe6MT's Avatar
-MN G Crew-
I replaced mine last week when one of my LEDs was out. Im OCD as hell and it finally got to me enough that i bought one off ebay.
It was brand new, and i got it for $100 shipped. Install was semi easy. Putting the second screw in is the hardest part, so i just left it out. One screw holding it in and it hasnt moved yet.
Very easy to do. Just find yourself a good deal on the assembly.
Old Jul 13, 2010 | 08:56 AM
last option sounds great, have you found any picture of 3rd LED brake light board?
Old Jul 13, 2010 | 08:59 AM
Is the coupe and sedan same part?
