Coupe springs on 06 g35x.
Old Apr 21, 2015 | 02:51 PM
dpark0223's Avatar
If i want to lower my car car on coupes, do i need to get the coupe struts too or can i use my stock struts with coupe springs.
Old Apr 21, 2015 | 08:41 PM
ScraggleRock's Avatar
I think it would lower the X one inch (? Someone correct me if I'm wrong), so you should be fine, but it may shorten the life slightly. When its time for new shocks tho, I'd go with coupe shocks.
Old Apr 21, 2015 | 11:38 PM
dpark0223's Avatar
So i dont need the coupe struts?
Old Apr 21, 2015 | 11:43 PM
Not for a one inch drop, no. Just double check that the drop is one inch, cuz anymore and I'd say yes.
Old Apr 22, 2015 | 02:20 AM
dpark0223's Avatar
Do i need to mess with the camber?
Old Apr 22, 2015 | 02:39 AM
All G35s need aftermarket camber adjustment, especially when lowered. Idgaf what anyone else tells you. And if you are lowered, you'll also need eccentric toe bolts in the rear.
Old Apr 22, 2015 | 10:15 PM
The Fixer's Avatar
You can reuse your original struts with the coupe springs. Coupe struts will not work on an X - the design is different at the bottom and you would not be able to bolt the bracket on that goes around the axle shafts onto a coupe strut. Here's a pic of what I'm talking about -
FYI, I put coupe springs on the front of my X, and it did drop it about an inch. I left the OG springs in the rear so the fender gap is equal from front to rear. Here's how she sits now.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
xplosive1
Aug 1, 2015 03:01 AM
Duriisimo
Jul 31, 2015 02:21 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
