Evap valve impossible to put in
Old Jun 18, 2015 | 08:39 PM
G35Fanatic06's Avatar
Hi all, I have an 04 g35x. Got a p0455 code so I decided to replace my valve. I got it off and sure enough it's messed up but I'm trying to put a new one in and it's being extremely difficult. Is there a particular angle?
Also, assuming I can't get it back in is it safe to drive without it? Right now the hose and plug is disconnected.
Also, if this is in the wrong forum I apologize.
Old Jun 18, 2015 | 11:19 PM
Mustang5L5's Avatar
Well with it unplugged you have a huge vacuum leak, and it's not fixing your code.
It goes in at a slightly off angle. It's been some time since I replaced mine, but not sure if it was 90 degrees to where it clicked into place. I do remember it took me a few tires to seat it.
Old Jun 18, 2015 | 11:38 PM
Would it be okay if I crimped the hose and rubber banded it? Not ideal but I need the car for work tomorrow. Fortunately I don't have a crazy commute.
The old one came out at 90 degrees but the new valve won't go in all the way in. How hard did you have to push in to get it snuggly in place?
Old Jun 19, 2015 | 01:35 PM
Mustang5L5's Avatar
I don't really remember. All I remember was fumbling around for a bit trying to find the right angle. basically insert the valve and turn it 360 in a circle until ot popl in, then you give it a final twist to seat it.
Old Jun 19, 2015 | 06:48 PM
I took a look at it again this morning. The trick is to angle it about 120 degrees. Once I had it the right way it was easy to push in and turn. I hooked everything back up and the ses light turned off after driving about 20 miles.
Thanks for your help!
Old Jun 20, 2015 | 05:23 PM
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
is this for the emission evap code? Ive had this issue for a while now. did you both replace the charcoal canister?
Old Jun 21, 2015 | 11:14 AM
Mustang5L5's Avatar
Yes P0455
Didn't replace the canister, just the Evap valve that twists into it.
OEM is about $100, Aftermarket off rockauto.com about $40. I did aftermarket. 6 mos later still fine
Old Jun 21, 2015 | 08:05 PM
Veteran: Navy
Veteran: Army
Originally Posted by Mustang5L5
Yes P0455
cool I may have to look into that
Muski_G
Dec 1, 2023 11:11 AM
brownie
Nov 25, 2015 12:50 AM
yassy
Aug 9, 2015 07:31 PM
lemmy999
Jul 25, 2015 12:13 PM
Jadenkid22
Jul 14, 2015 12:33 AM
