Cleaned up headlights!
Old Jun 20, 2015 | 11:12 PM
bananax's Avatar
I used plastix a few weeks ago, but that wasn't enough, and it started to get back to being foggy pretty quick. So today I took a more long term approach.
Wet sand the headlights (220grit)
Wet sand them again (1000 grit)
Use an orbital buffer with rubbing compound,
then polishing compound.
Now cover up the areas around the headlight, and use some clear coat spray paint!
I still need to do a polish on the clear coat tomorrow, but for today, I'm very pleased with the outcome!
It actually turned out awesome, much brighter at night as well, no more fog at all.
Before(only plastx used at this point):
After:
Pre-clear coat and polish.
Old Jun 20, 2015 | 11:19 PM
5150DS's Avatar
I always suggest UPol Clear #1. It is automotive grade and has a uv inhibitor built in. 2+ years later and mine are still clear. My car is 100% parked outside
http://www.amazon.com/U-Pol-Products-0796-Clear-CLEAR/dp/B009LHER0M
Old Jun 20, 2015 | 11:26 PM
gary c's Avatar
http://www.amazon.com/U-Pol-Products.../dp/B009LHER0M
BananaX, head lights look great! I suggest you follow this ^ advice for the clear coat since it's lasted two years also remarkable!
Gary
Old Jun 20, 2015 | 11:27 PM
Lartytiejdke3's Avatar
I always suggest UPol Clear #1. It is automotive grade and has a uv inhibitor built in. 2+ years later and mine are still clear. My car is 100% parked outside http://www.amazon.com/U-Pol-Products.../dp/B009LHER0M
always wondered how this held up
Old Jun 21, 2015 | 09:06 AM
Banikid's Avatar
Came out. Reminds me I have to do mine.
Old Jun 21, 2015 | 12:12 PM
Hotdawwgman's Avatar
That's awesome... I know I am suffering from foggy headlights... Great job
Old Jun 22, 2015 | 04:58 PM
The Fixer's Avatar
Great job, they look brand new again!
Old Jun 22, 2015 | 09:21 PM
markc's Avatar
Great job. I guess it takes some ***** to go at them with the sandpaper, but the results look to be well worth it.
Old Jul 2, 2015 | 06:53 AM
jrandys's Avatar
Looks good, but I agree on applying some sort of clear coat to protect your headlights from the harmful UV rays.
Old Jul 2, 2015 | 10:12 AM
Texasscout's Avatar
Boy, do I need to do this to mine.... Great job.
Old Jul 2, 2015 | 12:10 PM
bananax's Avatar
I did apply clear coat, UV resistant one, just not the same one mentioned here.
we'll see how long it lasts before needing another fix.
Old Jul 26, 2015 | 04:55 PM
hennessy45's Avatar
I followed original poster directions on left headlight, after 1/2 hrs of buffing headlight still have sand abrasive marking, using only rubbing and polishing compound took 5 min. and right headlight look as new... hope other have better results with sand papers than I....
Old Jul 26, 2015 | 08:39 PM
bananax's Avatar
glad it worked out for you. It seems to depend on how bad the headlight was to start. If it's a lite haze, you can probably get away with just the compounds. (or maybe it would be enough for even the worst?) trial and error.
Old Jul 27, 2015 | 01:12 AM
Urbanengineer's Avatar
You have to seal it again, with clear coat, or a similar application. Otherwise they WILL haze. I did mine every 18 months lol. Now it's been 3 years on my Honda.
Old Jul 27, 2015 | 09:29 AM
bizkardi's Avatar
Nice!
