Need rims help
Old Jul 10, 2015 | 04:55 PM
dpark0223's Avatar
Need rims help
Can i put 19inch rays on my 06 g35x with stock suspension? I dont want to mess with my suspension.
Old Jul 10, 2015 | 07:10 PM
bluedevils95's Avatar
Yes you can
Old Jul 10, 2015 | 08:56 PM
gary c's Avatar
The 19" rays from the '06 coupes look on sedans! There have been several sets for sale on our Marketplace under Private Classified 19" wheels. Good Luck & Enjoy the Ride!
Gary
Old Jul 10, 2015 | 08:57 PM
Albanian122's Avatar
Yes you can unless you want to lower the car later on 19 inch stock Rays will fit the car
Depends on what kind of fitment you want to achieve some like flush, static, or cambered out
Old Jul 10, 2015 | 09:26 PM
The Fixer's Avatar
The 19" Rays have different widths for front and rear, and usually run staggered size tires. Just make sure if you get them that the overall tire diameters wind up the same, or you will fry the transfer case.
Old Jul 10, 2015 | 10:18 PM
herrschaft's Avatar
^It's only a 1/2" / 2lb difference.
Old Jul 11, 2015 | 10:08 PM
The Fixer's Avatar
I know, I wasn't saying it because of the weight...the OP has an AWD model, so tire height needs to be the same front and rear. It he found a set with stock coupe tires, the rears are almost 3/4" taller (225/40 19 front vs. 245/40 19 rear). That will cause transfer case issues in the future if he just bolted them on as is.
Old Jul 11, 2015 | 11:47 PM
Urbanengineer's Avatar
Sedan 18" Rays clones achieve the look and ate 18x8.
Old Jul 13, 2015 | 11:57 PM
herrschaft's Avatar
It is possible to run a square setup on the OEM Rays. Which is why I pointed out the negligible stagger those wheels have.
Old Jul 14, 2015 | 09:55 PM
mushu's Avatar
I'm sure you can run the square set up. The difficulty you'll come across is piecing the set together.
Old Jul 20, 2015 | 11:16 AM
Mustang5L5's Avatar
Exactly. You need two pairs of fronts and have to run the same size tire. A little tricky to pull off
Old Jul 20, 2015 | 07:10 PM
dpark0223's Avatar
What if i get two pairs of rear? How would it be tricky to pull off?
Old Jul 20, 2015 | 08:56 PM
The Fixer's Avatar
It would be tricky because most people selling a set of Rays are not going to want to split them up and only sell 2. Most likely, you'd wind up buying 2 complete sets, and then selling off whatever ones you decide you don't want to run (either rears or fronts).
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
