nuts for studs on the catalytic convert
Old Jul 13, 2015 | 05:41 PM
si_driver's Avatar
I have searched everywhere but can't find any info about this.
I was replacing the old exhaust system and ran into a small problem. The nuts are rusted and can't reuse them.
I am looking nuts that are used on the bolts coming out of the catalytic converted. All of pieces of the exhaust use bolts and nuts, but the catalytic converter going into the y-pipe had studs. I need the nuts for these.
Could you tell me what the part # is or at least the exact size ,etc.
thanks,
Old Jul 13, 2015 | 09:34 PM
markc's Avatar
Have you tried inquiring @ the dealer?
Old Jul 14, 2015 | 05:57 AM
The Fixer's Avatar
If you can't find the right threaded nuts, you could always knock the studs out and just replace with fresh nuts and bolts.
Hope that helps!
Old Jul 14, 2015 | 08:20 AM
si_driver's Avatar
Makes sense..
I just did not want to be under the car banging on the stud and the expensive catalytic converter especially since it is old and has a lot of rust on it.
Hope that helps!
Old Jul 14, 2015 | 08:48 AM
LoSt180's Avatar
I think they're M10x1.25 As long as the nuts still have threads you can walk into an Ace Hardware and find the ones you need. Probably Lowe's or Home Depot also, but metric bolts at those locations are pretty limited.
Old Jul 14, 2015 | 12:29 PM
si_driver's Avatar
In case anyone else may need it:
the part number appears to be:
NUT-FRONT EXHAUST TUBE - [2060241G00]
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
NyCrAzY
Oct 1, 2015 09:19 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
