Need aux in my g
Old Aug 27, 2015 | 12:27 PM
Mustang5L5's Avatar
Originally Posted by Hotdawwgman
How well does it work?
I bought it because it retained the steering wheel controls.
Navigating through it is a little tricky and took a while to get used to it. You can access the menus through the readio headunit, and use the steering wheel controls for song advance, and volume, but it's slow to navigate if you actually wanted a song from a specific artist.
I set up a playlist, and just use that while on shuffle.
It has the old school iphone 4 hookup. I have to see if there is a lightning cable adapter for it as I have an iphone 6 now. You can play Pandora through it as well.
Old Aug 27, 2015 | 03:22 PM
Benja455's Avatar
My iSimple kit retained the volume controls on the stressing wheel. In my experience, the adaptors to convert the 30 pin plugs (iPhone 4) to the lightning port (iPhone 5 or iPhone 6) do not work for applications such as this. I suspect it won't work at all or you will lose steering wheel controls.
Old Aug 27, 2015 | 08:26 PM
Mustang5L5's Avatar
We will find out. Just bought one off ebay. $1.99 so not much risk really
Old Aug 31, 2015 | 04:53 PM
Hawk196's Avatar
03 G35 sedan....CD has a disc stuck and a cassette, so it only has the radio working. Is there a kit available for an '03?
TIA
Old Sep 1, 2015 | 08:19 PM
Mustang5L5's Avatar
You were right. Doesn't work at all.
Looks like in stuck using my old school 80GB iPod forever with it.
Old Sep 1, 2015 | 09:03 PM
Urbanengineer's Avatar
You were right. Doesn't work at all. Looks like in stuck using my old school 80GB iPod forever with it.
The speed of those old units is great! Simple because there is no garbage, just the basics .
Old Sep 2, 2015 | 08:08 AM
Mustang5L5's Avatar
Pretty reliable too. Going on over 10 years old here and still runs great despite being banged around quite frequently.
Old Sep 5, 2015 | 02:31 AM
Justice06RR's Avatar
Yea, I have one of the older 30gig Ipods and still works. I dropped it in the ocean (literally) and it still worked after it dried.
TIA
You have a couple of options.
1. FM transmitter from Besbuy, Ebay, Amazon, etc. Its the cheap option but not the best quality. I have the iSimple from bestbuy for $40, works fine but has interference sometimes.
2. Install an aftermarket deck.
Not sure if the kits mentioned previously will work with your 03.
Old Sep 11, 2015 | 08:22 AM
EasySausage's Avatar
Originally Posted by Raven7
You can get AUX jack installed or install bluetooth
I have a 05 X and it still has the factory radio I was just wondering if there is anyway to put a Bluetooth setup so I can listen to music rather than installing that aux you guys are talking about. If there is could you tell me the name of it and where to get it please. I don't want to change out my radio because I love the steering wheel controls so I would love to be able to listen to my music from my phone wirelessly with the stock radio so if possible please let my know!!
Old Sep 11, 2015 | 01:41 PM
Benja455's Avatar
Look at what I posted. That's one of your only options. Then check the larger audio thread - there a few other options...none of them are great, only good.
Old Sep 11, 2015 | 02:17 PM
Deepdiver's Avatar
the USA SPEC unit is the only way to go. It's been solid the past 6-7 yrs. Plus it retains the fuctionality of your steering wheel controls.
willdogs
Dec 8, 2015 11:32 AM
Daniel k.
Nov 3, 2015 09:52 AM
stratous01
Oct 7, 2015 10:19 AM
Gip
Aug 24, 2015 05:31 PM
