Ticking noise and slight rough idle...
Old May 8, 2003 | 06:07 PM
madler's Avatar
I just broke about 2400 miles on my car and just recently I started to hear a ticking noise (other then the fan) coming from the drivers side of the car. If I put my head near the drivers side front tire I can hear it clear as day (with AC On or Off). I've looked under the hood to determine if its coming from a belt with no luck.
Has anyone else had this problem or is this normal and I'm just hearing things?
Also, the car has started a slight, and I mean slight idle roughness when stopped at a light. The RPM's stay at around .5, which is low, so I'm not sure what happening? It also occurs with the AC On or Off. Up until a few days ago it didn't even feel like the car was running. Is it because the engine has finally burnt in and both these are just related?
thanks for any help.
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
dcsbh1
Oct 1, 2015 03:15 PM
