Automatic Driver Side Window Not Working
Old Oct 25, 2015 | 03:13 AM
jdubin94's Avatar
Hi there, for some reason, when I use the automatic, 1 click, window feature on my driver window, when the window gets to the top, it comes back down about 6 inches. I have to hold the button for it to shut. I don't believe it is a fuse problem because if a fuse was blown, it probably wouldn't work at all. So what do you guys think the problem is?
Old Oct 25, 2015 | 08:20 AM
Hogbone's Avatar
Hope this will help http://www.nicoclub.com/infiniti-service-manuals
Old Oct 25, 2015 | 10:00 AM
5150DS's Avatar
You have to reset the window limit. There is a button behind the door panel and a reset procedure on here somewhere. I just dont use the 1 click up on mine since mine does the same.
Old Oct 29, 2015 | 06:43 AM
05_SkylineSedan's Avatar
20 Year Member
The reason is your window thinks it has hit an obstruction (like your fingers) and is reopening because of the anti-pinch "feature". To reset the system on later models (not sure when this started) do his:
Start with the window fully open.
Pull up and hold the close switch.
Continue to hold the switch up for 2 seconds after the window has closed.
And that should do it. You've now trained the motor to know where the window frame is.
Hope that works.
Hogbone
Oct 27, 2015 08:16 PM
drogersno1
Oct 26, 2015 08:47 AM
G35-R
Lighting
Oct 24, 2015 12:02 PM
brett_murph
Oct 23, 2015 03:28 AM
