Radiator
Old Nov 18, 2015 | 07:49 PM
hennessy45's Avatar
Radiator
My 2003 sedan have a leak, I'm planning to purchase a replacement from Rockauto, has any members installed Denso or Spectra Premium radiator , and was it a perfect fit.. Thanks
Old Nov 21, 2015 | 09:43 PM
jrandys's Avatar
Aluminum radiators are a good choice. Koyo has good quality, and I know some guys here have this radiator.
Old Nov 28, 2015 | 11:17 AM
MikeDG's Avatar
My radiator blew in May and I replaced it with the Denso unit from Rockauto. It was almost a perfect fit. There are 2 plastic tabs on the bottom of the radiator that hold the ac condenser in place. The Denso's tabs stuck out about 1/4" more than the OEM radiator, so I had to use a dremel to remove a little bit of the lower rad. support to make it fit. I've put about 6000 miles on it and so far so good.
Old Nov 30, 2015 | 12:24 AM
hennessy45's Avatar
I replaced my G35 Sedan with Spectra Premium radiator after reading from other poster negatives review about Denso unit .... the Spectra radiator from Rockauto fit perfectly with the AC condenser, I was very happy with the unit , took me 5 hrs to replaced radiator , belts and thermostat
Old Dec 9, 2015 | 02:39 PM
2slickg35's Avatar
If you haven't installed a new radiator yet, I'd suggest going with a Mishimoto all aluminum radiator. Worked great for me with a perfect fit when I used to have a G35.
jeffbdye
Jun 1, 2018 03:51 PM
gDirty5's
Oct 26, 2015 08:49 AM
drogersno1
Oct 26, 2015 08:47 AM
Jorgebarrera
Sep 17, 2015 11:50 PM
jbmw002
Sep 3, 2015 08:42 PM
