Head light flickering after extending wires
Old Dec 8, 2015 | 11:49 PM
Tonycan2's Avatar
So I was doing the driver side loom and had to extend some wires, one being the headlight plug. After I was done I started the car and turned the lights on to make sure thay worked and the driver side is now flickering. I checked the new grounding location and made sure the plug was all the way snapped in but it is still flickering. I use 18g wire for all the wires I extended. Could I have blow the balast or build or is the wording need to be the same gauge as the existing wires for it to work properly?
Old Dec 9, 2015 | 05:00 AM
telcoman's Avatar
Veteran: Army
Undo what you did
The ECM and IPDM are no longer seeing normal.
The current and resistance values have changed
Read the FSM lighting section
Telcoman
Old Dec 9, 2015 | 07:03 AM
Tonycan2's Avatar
Originally Posted by telcoman
Undo what you did
Telcoman
Ok thanks. If I use the same size wire as what's on the harness would I be ok.
Old Dec 9, 2015 | 09:09 AM
Mustang5L5's Avatar
18 gauge is way too small.
You'll have to use the same gauge wire and ideally solder the connections
Old Dec 9, 2015 | 12:07 PM
Tonycan2's Avatar
I fixed it. Turns out one of my solder connections broke and I didn't catch it before wrapping up last night so I cut out the bad spot and re-soldered the wire. Everything is working like I should now.
Old Dec 9, 2015 | 12:29 PM
Urbanengineer's Avatar
Solder and then shrink tube it next time. It won't go anywhere.
Old Dec 9, 2015 | 01:33 PM
Tonycan2's Avatar
That's what I was planning on but I had already cut wires when I found out the shrink tubing I had was no longer good. It looked like it was half trunk on one side.
Old Dec 9, 2015 | 01:55 PM
Mustang5L5's Avatar
18G is still way to small. That's a fire hazard waiting to happen when that wire heats up from having too much current drawn thru it.
Old Dec 9, 2015 | 07:40 PM
saywat?'s Avatar
ugh so whyd u have to extend the wires?
Old Dec 9, 2015 | 09:42 PM
Tonycan2's Avatar
So it would reach. I tucked to through an existing hole right next the the ABS.
Old Dec 9, 2015 | 09:43 PM
Tonycan2's Avatar
What gauge should I have used.?
Old Dec 10, 2015 | 09:15 AM
Mustang5L5's Avatar
Equivalent of what is there now. Since I don't know what wire harness you extended, I can't comment further on it
AJC128
V36 Audio, Video & Electronics
12
Feb 14, 2022 08:10 PM
Ammar Dardari
Nov 16, 2015 09:41 AM
Albanian122
Nov 13, 2015 06:42 PM
EasySausage
Nov 13, 2015 08:07 AM
oskcazx
Nov 9, 2015 10:31 PM
