03 G35 oil consumption question
Old Nov 19, 2015 | 10:11 AM
dlodeuce4's Avatar
My 03 G35 MT6 speed burns oil at pretty high rate. When i change the oil at 3k i have 1 to 2 quarts that drain from the car. I know this isnt normal should I use an additive and if so what type? Maybe Restore or STP.
Old Nov 19, 2015 | 11:09 AM
CV35Driver's Avatar
Hey there,
Check for leaks all around your car. Check valve covers, gaskets, the whole 9. If you have not so, check the PCV valve and replace it with a clean OEM one. You can run a catch can system to check how much oil is being collected into the intake and prevent it from burning. I run a vented catch can system that is showing good usage every oil change. I went from consuming 2-3 Qts per 4K mile interval to about topping off 1Q every 4K miles which is acceptable given my cars age.
Oil is also a factor. Some oils may burn through quicker than others. I ran Castrol GTX and it drank through that like it was nothing. I switched over to Mobile Euro 0w40 and am seeing noticeable improvements.
For a peace of mind, you can also do a compression test on all cylinders and check the problem source of the oil consumption.
Additives won't do much to fix this problem from my experience.
Hope this helps
-Ali
Old Nov 24, 2015 | 08:49 AM
Mustang5L5's Avatar
Start carrying around quarts of oil in your trunk.
My '06 is burning about 1 qt per 1K miles now. I just carry 1-2 quarts in the trunk and always check and add.
Not much I can do really, and honestly, with 164K miles and car long since paid off...i'm just buying time til I trade it in on a G37x.
Old Nov 24, 2015 | 10:54 AM
Fire0nic3's Avatar
My 06x is burning oil too. About 1 quart every 1800-2000 miles.
I noticed it burns oil faster if I drive it harder. Otherwise it burns it around the rate like I previously mentioned.
I changed the PCV valve amd that didnt fix it. I also checked for oil in the spark plug tubes and valve covers and it was bone dry.
Other than that I have absolutely no idea where the oil is going.
Old Nov 24, 2015 | 10:55 AM
Fire0nic3's Avatar
Hoping it doesnt get worse the more miles I rack up. I have 160k miles
Old Nov 24, 2015 | 03:30 PM
Mustang5L5's Avatar
Mine got progressively worse.
Under 50K miles, it was 1/2 quart every oil change. Around 50-100K it was maybe 1-1.5 quarts per change. Now i'm at 2-3 per oil change.
GrayG35
Nov 15, 2016 12:54 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
(>")> G35
Jan 7, 2011 08:04 PM
gcode
Mar 23, 2010 02:10 PM
wilksoner
Nov 14, 2006 12:14 PM
