clutch upgrade options...
Old Nov 19, 2015 | 10:15 AM
TheIronYuppy's Avatar
Hi all
It's time to replace the original clutch in my 04 Sedan. 90k... not bad!
I want to keep it quiet and smooth, but I want to upgrade the "grab" of the clutch. Something that works with the stock flywheel.
Suggestions?
Old Nov 19, 2015 | 10:19 AM
Texasscout's Avatar
If you must keep the stock FW, go with an oem clutch. Odds are, you will need to replace the FW anyway as they are not machineable. So why not just go with a Jim Wolf Technology clutch pack?
Old Nov 19, 2015 | 03:04 PM
I did a little legwork on the JWT. It looks great, but I am worried about losing OEM quiet and smoothness. Would that be an issue?
Old Nov 19, 2015 | 03:50 PM
gary c's Avatar
Stay with an OE clutch, new they'll grab just like you want! Aftermarket clutches are cool but I don't know of one that doesn't make some type of chatter or cause other issues...Gary
Old Nov 19, 2015 | 04:40 PM
Texasscout's Avatar
It's not an issue with ME, you mileage may vary.
Yes, you will have clutch chatter. It bothered me at first by now I don't even notice it.
The reason I went with JWT clutch was that EVERY part is replaceable. Even the flywheel has removable friction surfaces. Also, if I ever decide to boost it, it's good for 450+ hp. Yes it gives your leg a workout, but my wife drives it everyday if that shows you anything.
Besides the kit came with: Flywheel, HD pressure plate, clutch disc, TO bearing, pivot bearing, installation tool and a SS slave line all for less than $800.00 It cost me $400.00 to get it put in. A new OEM clutch job from the dealer is $2200.00 AT LEAST.
Old Nov 19, 2015 | 07:06 PM
saywat?'s Avatar
oem clutch prices online really isnt that bad its the oem flywheel price that will kill u lol
Old Nov 19, 2015 | 07:17 PM
sick_sixspeed's Avatar
I can't believe this. I've called 3 different shops including a Nissan dealership to get quotes on a clutch replacement and all 3 have recommended to go with the JWT clutch and fly. Is it really the best clutch kit for the g and z?
Old Nov 19, 2015 | 07:19 PM
JWT has a nodular iron flywheel that weighs in at 26 lbs. basically same weight as oem flywheel. So you don't have to live with the chatter of the 15 lb lightweight fly
Old Nov 19, 2015 | 07:24 PM
I just ordered my JWT clutch with the 26 lb flywheel from CZP for $550.
Old Nov 20, 2015 | 12:05 AM
Am I missing something? I'm only seeing 26lb units on JWT's site.
Old Nov 18, 2016 | 08:50 AM
nism0b0y's Avatar
how have you liked it? is the chatter bad at all? mine is shot on my coupe and I may be selling it right after I replace it. the oem clutch and fly are both shot dead. so I need a good replacement
Old Nov 18, 2016 | 09:18 AM
Texasscout's Avatar
If you are going to sell it, don't get the JWT. Get an aftermarket "dual mass" flywheel and OEM style clutch. People that don't understand lightweight fly wheels and why they make noise, will be put off my the rattle. I don't even hear mine now I'm so used to it.
sales@aamcomp
Engine-Vendor
Aug 1, 2016 12:52 AM
heynow
Tuner & Dyno
Nov 30, 2015 08:01 PM
deathdoakill
Nov 18, 2015 09:04 PM
Albanian122
Nov 13, 2015 06:42 PM
EasySausage
Nov 13, 2015 08:07 AM
