Modifying the stock midpipe
Old Feb 24, 2005 | 12:19 AM
dklau33's Avatar
Originally Posted by Gting
Why are people using mufflers and not resonators to replace the stock premuff? Magnaflow has a 2.5" x 22" stainless steel resonator. Part #14498
Mufflers and resonators serve the same purpose, to cancel out the exhaust sound waves and quiet down the exhaust noise. Don't get hung up on that so much.
Old Feb 24, 2005 | 12:27 AM
Gsedan35's Avatar
Hey how would the Magnaflow 14" x 2.5" (4" round) stainless steel muffler sound with the stock muffler? I did some searching and you suggested not to go with the 14"
The shorter the muffler body, the greater the noise generated at the critical 2500rpm range. Even with the 22" muffler I had in place, it still did make some droning in the 2500rpm range. Though not near the level that the Stillen TD does. If the noise issue matter's to you, look into this. Dynomax makes a ultraflow SS muffler that has a slim profile, 4 1/4" by 9 3/4", it should offer greater noise suppression. Either part number 17283 or 17289
http://www.dynomax.com/documents/ultrafloss_specs.pdf
Old Feb 24, 2005 | 12:47 AM
Gting's Avatar
Thanks I appreciate the input.
Old Feb 25, 2005 | 03:56 AM
Hyde's Avatar
the stock muffler gives a high pitch sound in the first place.
sounds kinda like the 360 Modena.
HKS + straight mid + Y-pipe is the ****.
philbegas
Jul 8, 2016 07:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
gatorglaze
Sep 19, 2015 12:06 PM
vstring
Sep 11, 2015 02:50 PM
kevintandmd
Sep 3, 2015 06:41 PM
