I have an 04 G35x
I just had all 4 brakes done (pads and rotors) and now these lights are on the dash. My car kinda hesitates to accelerate and cruise control does not work.
These are the codes I have:
C1131 Brakes
P2128 Sensor High Voltage
2138 Wrong APP Sensor Rationality Signal
V1000 Transmission
P1815
P1705 TPS Sensor
Anyone know what the issue(s) might be?
Just spent $1000 for the brakes and a new wheel bearing so I hope it's something DIY!
Thanks for the help.
C1131 Brakes
V1000 Transmission
P1815
P1705 TPS Sensor
bigc
Wings Nation
close
- Join DateFeb 2007
- LocationSoCal
iTrader Positive Feedback100
iTrader Feedback Score(59)
Liked:626 Times in 456 Posts
take it back to the shop and have them make sure your ABS sensors are in proper alignment. the tech may have knocked one out of alignment. before you head out though, make sure your brake fluid is at the correct level (might as well eliminate one possibility).
No ABS light?
Only thing I can see a brake job damaging would be one of the ABS wheel sensors. Other than that the car has nl clue what's going on with the brake system.
If the ABS light is not on, then I wouldn't suspect a sensor got knocked out of place or cut.
agreee with bigc - Check your brake fluid level first. Even if it doesn't look low, add a little as the level sensor float may be hung up. Had the same thing happen to me not too long ago.
