Slowly, but don't call me surely "build"
Old Jan 25, 2016 | 01:38 PM
Jake The Snake's Avatar
Originally Posted by ScraggleRock
Cover the holes with glued on nickels!
Funny story... The first 240sx I owned had holes in the trunk lid from a spoiler removal. I glued quarters to the bottom side and filled the top side with bondo. Don't worry, it was just a phase.
yeah let me know. my relationship with ScraggleRock has been on the downturn ever since he said "Led Zeppelin sucks"
He's clearly wrong about Zeppelin but the nickel idea isn't half bad.
Old Jan 25, 2016 | 01:48 PM
CV35Driver's Avatar
Off to a great start man!
Wheels look great on the Sedan.
Side note- all four have to be same size tire diameter all around. Check this tool out to help with tire measurements and how to stay close to stock diameter for the speedometer.
http://www.rimsntires.com/specspro.jsp
I used this tool myself with my wheels.
Hope this helps out!
-Ali
Old Jan 25, 2016 | 01:54 PM
ScraggleRock's Avatar
Quarters? You wasted $.20/hole. Assuming there were 4 holes, $.80 is enough to rent Taylor for an hour or two of buddy-jamming to LedZep.
Old Jan 25, 2016 | 02:14 PM
-Ali
Thank you! Two of the tires the wheels came with are ruined so I plan to buy tires so that all 4 are matching. 235 35r19 most likely
Should've used some nickels flattened on the rail road tracks. I feel I'm too new to the forum to take sides here but $0.80/hour seems like a pretty good deal.
Anyways, I may do some research on doing a wire tuck. I started polishing the plenum cover but don't have access to an air compressor right now. A polished and tucked bay would look nice
Old Jan 25, 2016 | 02:36 PM
Lartytiejdke3's Avatar
Psh bic
Better spent buying you a copy of LZ at MSG '73
Old Jan 25, 2016 | 02:41 PM
yosip1115's Avatar
Check out baidpolish on IG
Old Jan 26, 2016 | 12:44 AM
My favorite part is the group purchase sensor.
What do you all recommend for a buffer and high gloss polish?
Old Jan 26, 2016 | 07:58 AM
jbarnett250's Avatar
I have a porter cable 7424xp and like meguiars a205 and a105 for heavy/light polishing. My buddy bought a $40 polisher from harbor freight and it seems to work just as good.
Old Jan 26, 2016 | 09:53 AM
Mustang5L5's Avatar
Originally Posted by 5150DS
I believe the 05 and 06 have holes underneath.
Those are speed holes
Old Jan 26, 2016 | 01:18 PM
I'll have to look into that. Thanks! I want to blind pilots with the shine on my car.
You're my favorite G35driver member now
Old Jan 27, 2016 | 04:45 PM
This just in
Today I ordered some of that gold heat wrap stuff. Going to try it on my intake and test temps just for fun. Also ordered bolts and washers from a fastener website for the engine bay dress up
Old Jan 27, 2016 | 07:49 PM
Something to keep my back tires on the ground
For $60 the paint on this looks good to me. Garage was too cold to put it on tonight.
Old Jan 28, 2016 | 01:33 AM
Tyke420's Avatar
^ Can't wait to see what it looks like on your ride...! Seems like your heading in the right direction.
Old Jan 30, 2016 | 10:34 PM
Thank you! I'm excited as well.
Got a floor jack today and wrapped up my intake tube. You can see where i had started to polish the plenum but ran out of time a couple weeks ago.
Should have the spring on Tuesday
Old Feb 10, 2016 | 02:52 PM
  #30
I'm not dead.
Got these from aliens fasteners
Makes the engine bay look a little nicer
Installed my lowering springs but I'm not happy with how it sits. Looks like I'm going to end up getting coil overs. Seems most X guys use the BC brand, is this the best available or what are the other affordable options?
