Need headlights
Old Mar 1, 2016 | 09:51 PM
m17davis's Avatar
Need headlights
Ive been doing research on the 06 upgrade. I have a 04 g35 sedan. I want to go to the 06 headlights but I keep seeing 06 coupe headlights wherever I look. Is there a difference between 06 sedan and coupe headlights?
Old Mar 1, 2016 | 10:34 PM
Urbanengineer's Avatar
Yeah they are completely different. You can only buy ones for the sedan. If you don't mind some haze there are some part out threads here.
Old Mar 2, 2016 | 12:28 PM
Mustang5L5's Avatar
Also, the 05+ headlights are not a direct bolt in. Technically the front fascia is slightly different so the headlights don't fit correctly. To do it right will require changing out some bodywork.
The 06 upgrade is really a coupe thing as they had projectors that year. 2006 sedan lights are pretty much the same as your 2003 lights. If you don't have HID's, look for a set of 2004 headlights for a direct bolt in.
Coupes are different, so can't use those lights at all
Old Mar 2, 2016 | 01:10 PM
gary c's Avatar
We have vendors on our Marketplace that have parts to upgrade you sedan headlights if that's what you're interested in doing since coupe headlights won't work on sedans! Although I don't recommend doing so, you might to find an outside vendor for new or upgraded headlights...choices!
Gary
Old Mar 2, 2016 | 08:00 PM
m17davis's Avatar
Dam
So I either replace my one headlight with a oem one. Or I buy a set of shitty aftermarket ones? Is there a way to make the stock ones better?
Old Mar 2, 2016 | 10:17 PM
eazdaskeez's Avatar
Originally Posted by m17davis
dam
so i either replace my one headlight with a oem one. Or i buy a set of shitty aftermarket ones? Is there a way to make the stock ones better?
retrofit
Old Mar 7, 2016 | 03:12 PM
infinitidude's Avatar
OEM headlights are around 1800 a set so you just have to figure out the option that works best for you my friend.
Fire0nic3
Jul 23, 2016 09:42 PM
miltoda
Interior
Jul 11, 2016 10:31 AM
Gunz_VQ
Feb 5, 2016 11:01 AM
Karran Dhanroop
Jan 14, 2016 08:32 AM
RA081024
Lights
Dec 28, 2015 08:24 PM
