Grubbs aluminum pedals easy to install?
Old Apr 10, 2005 | 02:32 PM
  #31
thfx's Avatar
I installed the kit from everything G35 for auto and install was pretty simple except accelerator pedal clip was pita to remove. I used a small stubby screwdriver for the brake pedal cover. I also came up with a way to screw the clutch pedal onto the e-brake plate (there is a nice hole in the plate under the stock rubber boot). Only two comments I have about this setup is 1) my shin tends to hit the ebrake now and 2) the accelerator pedal is a bit loose...considering placing shim behind it to keep it tight and remove the "clink" sound when I hit the gas.
Muski_G
Dec 1, 2023 11:11 AM
11bEMT
May 27, 2022 03:13 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
