Grubbs aluminum pedals easy to install?
Old Feb 24, 2005 | 02:17 AM
BobbyG123's Avatar
Curious if the Grubbs pedals are easy to install? I guess what I really mean to ask is when they're installed, are they TOTALLY stable or do they wobble around?
Thanks.
Old Feb 24, 2005 | 10:00 AM
erik7's Avatar
Howdy!
And to follow up, they actually replace the rubber pedals and aren't stick ons? I'm pretty sure of this, but I want to double check with someone who has them. Will probably be my first mod.
Old Feb 24, 2005 | 11:17 AM
Grotman's Avatar
Yes they're easy to install. I did it in about 25 minutes the other day. Only hard part is the position you need to be in to get down under there. Just pry off the old rubber ones and the new ones fit on the same way they came off. Nice and tight, no slip.
I just used a moderate flat head screwdriver to get the pad lip over the pedal. Just get one of the ends started then run the screwdriver around it to get the rest of the lip over it.
The gas pedal goes on with a bushing and a clip. All pretty intuitive to do.
Old Feb 24, 2005 | 01:13 PM
BobbyG123's Avatar
Do the factory pedals become destroyed as a result of removing them? I'd like to think that if for whatever reason if I don't like the Grubbs, I can always go back to stock.
Thanks.
Old Feb 24, 2005 | 02:46 PM
G35Papa's Avatar
No, they don't become destroyed. Unless your get pissed when taking them off and pull out a hacksaw
Old Feb 24, 2005 | 02:49 PM
nate's Avatar
6mt pedals are a bit harder being smaller and having 2 to pry on (brake & clutch). previous tips included using a hairdryer or soaking in warm water (caution for rust potential) to make them more pliable. Another was to use silicone spray or other lubricant.
Once on, no issues at all with moving around.
Factory pedals are fine, but I suppose you could put them on again. Taking them off is WAY easier than putting on, so they don't get destroyed taking off.
Old Feb 24, 2005 | 03:29 PM
cato's Avatar
SouthernComfort Moderator
Thanks.
You will NEVER want to go back to stock.
Old Feb 24, 2005 | 03:33 PM
callawayc7's Avatar
Does anybody have a picture of it installed in their car? It looks pretty good on the Grubbs website but it's hard to tell what it "really" looks like once it is installed. Thanks.
Old Feb 24, 2005 | 03:43 PM
aam6906's Avatar
i dont think aluminum pedals do too much, but they are easy to install(cept the brake) and do add a nice loook to the pedals.......
Old Feb 24, 2005 | 04:27 PM
nate's Avatar
Yeah, you won't want to go back either.
Old Feb 24, 2005 | 05:36 PM
callawayc7's Avatar
Thumbs up
Thanks a lot for the picture, Nate. Look great!
Old Feb 24, 2005 | 07:41 PM
amg35's Avatar
Florida G35 Club
Does the e-brake pedal get replaced on a 5AT? Thanks.
Old Feb 24, 2005 | 08:57 PM
callawayc7's Avatar
It can be for $21 more! They sell them separately from the 5AT set. I'm still deciding if I will get the set or not. Although it looks nice, seems kind of pricey for a few pieces of metal.
Old Feb 24, 2005 | 09:04 PM
amg35's Avatar
Florida G35 Club
Everything G35 has a set that includes the e-brake for $73.50.
Old Feb 25, 2005 | 12:35 AM
nate's Avatar
I have 6mt (handbrake), so I can't say for sure, but I've read that the parking brake is not a direct replacement. Some people have glued it on, screwed it on, and even cut away the factory rubber to get it to fit. Sounds pretty nasty, so read up on that first.
Located the install guide:
http://www.smiley.net/g35/pedals.htm
Also, attached a pic of Grubbs' auto install example.
