Valve cover leaking into spark plug
Old Sep 19, 2016 | 12:36 PM
Acagrill's Avatar
I can appreciate that but I was reading another thread: "Replacing the spark plug well seals in the valve covers" and the instruction are good on how to replace the seals using the drill out method. Also here is a utube from R & D on how to DIY. The cost for the seals are very cheap vs the covers.
Old Sep 19, 2016 | 12:39 PM
dat_skyline's Avatar
Originally Posted by Acagrill
I can appreciate but I was reading another thread: "Replacing the spark plug well seals in the valve covers" and the instruction are good on how to replace the seals using the drill out method. Also here is a utube from R & D on how to DIY. The cost for the seals are very cheap vs the covers.
R&D Factory 350Z 370Z G35 G37 FX35 FX37, VALVE COVER GASKET AND O-RING DIY - YouTube
Well its your car but after consideration I concluded that that was not a good idea for my car. I don't think method would last very long. Good luck either way man
Old Sep 19, 2016 | 12:40 PM
The 350z valve covers should be interchangeable with g35 valve covers so following 350z instructions should work
Old Sep 19, 2016 | 01:05 PM
Acagrill's Avatar
Thanks dat_skyline
Croykey
Mar 16, 2016 12:52 AM
RedBaronK
Mar 8, 2016 02:04 AM
slicrick
Lighting
Mar 3, 2016 08:48 PM
Jnovuse
Mar 3, 2016 11:56 AM
