Old Lady hit and run
Old Apr 30, 2016 | 09:24 PM
Karl Horn's Avatar
I was in Fred Meyer with the GF and some old lady took out my door and front end. Ruined my retrofit headlight. Insurance paid for everything tho, thank god for full coverage. Just got my OEM reconditioned Nismo sedan bumper!
Got hooked up with a set of poem clear corners from a member on here
I'll update when everything gets put on and painted at the shop. Should be looking a lot better soon
Old Apr 30, 2016 | 09:38 PM
Mr. Brooks's Avatar
Thumbs down Here's what you do
I would go back to the area and see if their are any cameras. Although no one was injured (thank God), hit and run is a serious offense.
Old May 1, 2016 | 03:45 PM
Karl Horn's Avatar
Test fit the nismo bumper today.
Old May 1, 2016 | 04:24 PM
hurleyguys's Avatar
that sucks but def a good time to upgrade the bumper. looks good so far
Old May 15, 2016 | 07:37 PM
Karl Horn's Avatar
Working on the new retrofit
Old May 15, 2016 | 07:41 PM
Karl Horn's Avatar
So the nismo bumper isn't fitting perfectly. It seems to be hitting on something and that is keeping it from fitting on. Its somewhere in the lower area. The shop is also having this issue with fitment. I told them to just paint it and get it on as good as they can and I would figure it out. Anyone else done the swap from OEM bumper to OEM nismo bumper and had any issues? Is there a support I need to remove or something simple like that? I hope it isn't the whole metal bumper reinforcement that needs to be changed out. Any help would be appreciated.
Old May 15, 2016 | 08:05 PM
edubb11's Avatar
There are some metal pieces that need to be removed for the bumper to fit. This thread will help: https://g35driver.com/forums/body-in...r-install.html
BTW where did you get your bumper? I just got a reconditioned one and it didn't come with the fins / inserts. Hoping I can get a set.
Old May 15, 2016 | 11:45 PM
Karl Horn's Avatar
I got it from RockAuto.com and it came with the fins. It was also reconditioned. I guess I got lucky
Old May 18, 2016 | 08:31 PM
Karl Horn's Avatar
All new again
Old May 18, 2016 | 10:54 PM
Karl Horn's Avatar
After 3 hours of searching for the part number for the nismo rear lip, I cannot find it. Anyone have the part number?
Old May 19, 2016 | 07:45 PM
ray1370's Avatar
Part number with color code:
H5920-AM562, BW5
H5920-AM565, KH3
H5920-AM567, KX6
H5920-AM568, QX1
H5920-AM570, KY0
H5920-AM572, AY2
H5920-AM574, D10
H5920-AM516, B16
1999sel
Nov 19, 2017 12:23 PM
irishsig
Oct 24, 2016 03:43 PM
lag35driver
Northern California
Jul 3, 2016 11:03 AM
JoshuaDunand
Mar 21, 2016 03:49 PM
grantshurtz
Mar 12, 2016 07:52 PM
