Hi, I searched a lot of threads and could not find an answer to this... Can you install the passenger seat on the drivers side? I understand the controls would be on the wrong side but I'm ok with that. My drivers seat is worn out from every day use and I want to get a passenger seat from the junkyard that is in like new condition to replace it. Is it a direct bolt replacement? Is the wire harness the same?
Thanks for any help!
No it's not a direct bolt-on, and not only the controls but also seat belt buckle would be on the wrong side too. Just get a driver seat and save yourself some headache. Btw if you're in SoCal I might be able to help.
