2003 RWD Sedan - Front Lower Control Arm / Transverse Link Bushings Bad?
Old Jul 19, 2017 | 02:58 PM
achillesg's Avatar
When replacing my starter last night I noticed this arm (called a transverse link in the manual, AKA lower control arm) had a bad bushing at the far side away from the wheel, and the eye-end is smashed against a frame piece. Both driver's side and pax have the same condition. I tried pushing the arm on the raised side towards center and it gives only slightly. Not making any noticeable clunking noises. See pics.
1) Do these need to be replaced if there's no noticeable noise or vibration? Can it be "silent but deadly"?
2) I've been reading mixed reviews on replaced bushings, is it better/easier to replace the whole arm? I do have access to a 20 ton press. Bushings are $20-60 and the arm is $87 from AAP.
2003 sedan, 178k miles, stock. Never lowered. Will probably drive until it can't anymore.
Thanks in advance!
Old Jul 19, 2017 | 03:02 PM
achillesg's Avatar
Links to parts I found searching AAP, not sure if these are the right bushings!
MOOG Control Arm Bushing
Part No. K200967
https://shop.advanceautoparts.com/p/...ushing+-+lower
MOOG Control Arm
Part No. RK641594
Search results:
https://shop.advanceautoparts.com/we...hedFrom=header
Old Jul 19, 2017 | 11:12 PM
ramirezmartin98's Avatar
i changed out the lower control arm completely on both sides. i used amazon and got them the next day with prime!
