v35
Old Mar 31, 2018 | 10:40 AM
boppy2's Avatar
v35
i have a 02 skyline it had couple sensors changed after the timing chaing went so i have to change that but wen i try to start it p0340 code and the knock sensor showed up everytme i would try to reset the ecu it wout rev to 3000 2000 and the idle drops and stall i change coils and throttle . some please help
Old Apr 4, 2018 | 01:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you sure the cams were properly aligned when the new chain was installed? If so then just replace the bank1 cam position sensor and see if the P0340 code goes away.
Old Apr 5, 2018 | 08:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
If you replace the cam sensor make sure it's an authentic Nissan piece. Our cars often don't play well with aftermarket ones.
Old Apr 5, 2018 | 06:27 PM
boppy2's Avatar
i aint change the timing yet . after i had them couple sensors change only them two showed up but i change the fuel pump . but it still starts , idle rough and sometime if i catch it right it would idle up but if i let go it'll cut off .
six20aus
13
Jan 14, 2022 07:06 PM
sales@czp
Suspension-Vendor
Feb 9, 2018 12:11 PM
Acp1986
Sep 21, 2017 01:52 PM
JZ
Aug 18, 2016 11:05 PM
