Please Help Identify This Part
Old Apr 25, 2018 | 10:35 PM
Jdm127's Avatar
I found this on our garage floor underneath the engine area of our 2005 G35X Sedan. Can someone please help me identify what it is and what it does. How important is it?
Old Apr 25, 2018 | 10:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wierd, I have no idea what that is?
Old Apr 25, 2018 | 11:52 PM
Blue Dream's Avatar
I drove ttrank's car solo
Me neither, I'm pretty sure I've never seen something like it on my G.
Old Apr 26, 2018 | 11:40 AM
MooseLucifer's Avatar
5 Year Member
blk
I've seen that before.. but I don't remember where! I'm pretty sure it was a dampener for the exhaust or something.
Old Apr 26, 2018 | 02:39 PM
cswlightning's Avatar
....Weight savings? If it rusted off and you didn't notice anything, don't worry about it!
Old Apr 26, 2018 | 03:20 PM
cleric670's Avatar
BANNED!!!
Muffler bearings?
Old Apr 26, 2018 | 04:01 PM
telcoman's Avatar
Veteran: Army
Put the vehicle up on a lift for a through inspection.
Telcoman
Old Apr 26, 2018 | 07:41 PM
^^ This is the best answer - Just look for the rustiest place on the undercarriage and lo and behold, its home!
Old Apr 26, 2018 | 08:01 PM
herrschaft's Avatar
I'm 99.9% certain that is not off your car. Unless you have an X than I'm not sure.
Old Apr 26, 2018 | 08:33 PM
Jdm127's Avatar
It is an X
Old Apr 27, 2018 | 03:40 PM
jbarnett250's Avatar
can't believe cleric was stumped. i've seen that on my x too. i don't know what it's for. it's just below the transmission somewhere. it's a bunch of weights and they're mounted to something that's a little springy. almost like curb feelers for the bottom of your car. but honestly doesn't look like it would help save anything if you drag it.
Old Apr 27, 2018 | 05:34 PM
Jdm127's Avatar
Thanks, I did look under the car, and there seemed to be a spot similar to what you are talking about where it seemed to fit, just didn't make sense as it was as you say squishy. Does anybody body have any idea what it's purpose is and and problems if we continue to drive the car?
Old Apr 27, 2018 | 10:04 PM
G2B35AGN's Avatar
I have no idea but I was intrigued enough to poke around the diagrams on the InfinitiPartsDeal site. A ruler in the photo would be nice to get a sense of scale.
Is it possible that this is a "Heat Insulator - Front Floor"? That seems to be the only thing I can see that remotely has the appearance and shape of what you are showing in the pics. There are two, one right hand and one left hand.
https://www.infinitipartsdeal.com/pa...rs=74752-AM600
Old Apr 28, 2018 | 10:53 PM
Jdm127's Avatar
Size
It is approximately 3.25 x 2 inches
Old Apr 30, 2018 | 12:04 PM
fitgineer_93's Avatar
Just changed the transfer case fluid and did a drain/fill on my tranny this weekend. I noticed that sticking out from underneath the vehicle and also wondered what the hell it was.
Mine was also "squishy" if you pressed on it and it was able to move side to side. It was attached to the exhaust pipe just downstream of the y-pipe; I agree it is probably for vibration dampening. I would like to say it also protects from road interference but seeing as it was easy to manipulate, chances are it wouldn't do so well against a rock.
In short, you're fine without it. Your car is still going to function all the same.
