Mods and Troubles
Old Jun 9, 2018 | 02:03 PM
Gator87's Avatar
Mods and Troubles
Yesterday installed plenum spacer and new larger 75mm TB. Today not even 24 hours later ses light code P0507-High idle speed control. Did the off on pedal dance and tried the other relearn tactics light was off for about 3 hours and now it's back on. Suggestions comments ideas what to do about this??
Old Jun 9, 2018 | 02:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably a vacuum leak. Which of the pedal dances did you do exactly, you should have performed three, throttle closed, idle air, and ECU reset.
Old Jun 9, 2018 | 03:00 PM
Gator87's Avatar
I did all three of them. I hope it's not a vacuum leak. That would suck. Nothing that I can see or find is obviously wrong with the install and I got new gaskets and everything all ordered from Z1 Motorsports.
Old Jun 9, 2018 | 03:58 PM
cleric670's Avatar
BANNED!!!
And you're sure you didn't pinch a little bit of the oil fill neck?
Old Jun 9, 2018 | 08:06 PM
Magneu's Avatar
5 Year Member
G35C 5AT
^Been there. If your engine is screaming like the souls of the damned, that's the culprit right there.
But yeah, probably a vacuum leak.
Old Jun 9, 2018 | 08:12 PM
cleric670's Avatar
BANNED!!!
Sometimes it's just BAAAAAARELY pinched and you don't even hear it over the normal engine noise but it will definitely screw the A/F and idle.
Old Jun 9, 2018 | 08:37 PM
Gator87's Avatar
Checking
Thank you for the input and replies on this. I will check again tomorrow but I didn't see anything pinched in however I will check again. I dont hear it "screaming" it's idle is at 750-900 runs great no stalling etc. Great response time for throttle and everything else seems good.
panda007
Drivetrain
Dec 5, 2005 05:28 PM
SFLG35
Florida G Club
29
Jun 10, 2005 09:54 PM
dicosmo
Jan 25, 2005 05:24 PM
godlike0104
Dec 24, 2004 11:18 AM
