Fuel pump module for sedan?
Old Jul 26, 2018 | 11:53 AM
TDL's Avatar
TDL
I'm having trouble finding the fuel pump module (with sending unit) for my 2006 G35x sedan. All units I see online are for the coupe, not the sedan. Can someone point me where it can be purchased, or to a part number?
I've found part number 69700 by Bosch on Carid which says it fits the x sedan (https://www.carid.com/2006-infiniti-...250908487.html), but other websites say this part doesn't fit the sedan.
My car has had the notorious fuel gauge problem for 3 years and it recently started having trouble starting. It cranks fine but doesn't fire up quickly... just like it is out of gas. It's getting worse and worse. I think the fuel pump is going or possibly some sort of check valve within the fuel pump assembly is bad. I'd like to just replace the whole thing. Thanks
Old Jul 26, 2018 | 12:22 PM
coffeysm's Avatar
It could be this grommet located in the fuel pump assembly:
https://www.z1motorsports.com/fuel-p...et-p-8376.html
It could also be your sending modules causing the fuel gauge problem. I have a coupe and bought a new pump and sending unit as well. I haven't installed them yet though.
Old Jul 28, 2018 | 01:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get one of these and put it on the car so you can check fuel pressure, make sure to order either a gauge or the mini schrader valve (or both!) from the options on the bottom.
https://www.z1motorsports.com/z1-pro...rt-p-9160.html
iTzTeddy
Apr 13, 2016 06:18 PM
DVG
Engine - Intake/Fuel
Oct 1, 2014 09:32 AM
HotRodG35
Aug 31, 2013 04:25 PM
bokchilo
Oct 14, 2011 02:18 PM
