Check engine light reset after hitting a bump?
Old Oct 17, 2018 | 08:26 PM
Ichiglo_'s Avatar
so I’ve been having a cel light on for cam sensors and I already replaced them but haven’t reset my cel light.On my ride home from work today driving my lowered g,I hit a nasty yellow bump that hit my undercarriage really hard that made me Shed a tear lol anyways I noticed after I hit the bump my cel light was wiped away from my dash.What could have happened? Have any of you guys experienced this before? It’s a little strange
Old Oct 17, 2018 | 09:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Possibly a damaged or contaminated wiring harness. Take everything apart, inspect, clean.
CEL will also typically clear itself when the issue is no longer present. Might be physical damage inside your cam sensor and something on that winding moved and made better contact with the pins, I suspect internal soldering was failing and the vibration made it slightly work again.
This is probably fate giving you one last chance to fix the problem before it leaves you stranded on the side of the highway when the cam sensor fully fails.
Old Oct 18, 2018 | 09:22 AM
Ichiglo_'s Avatar
My cam sensors were literally replaced last weekend so I doubt my sensors are messed up already lol all the wiring looks okay
Old Oct 19, 2018 | 06:46 PM
cleric670's Avatar
BANNED!!!
You can't tell if the harness is contaminated by looking at the outside of it. It's a 30 second job to unplug them and look inside with a flashlight to make sure there's nothing contaminating it, use an inspection mirror for the actual sensor.
PaulaMae94
Aug 17, 2012 01:08 PM
scrapiron7
Jul 21, 2009 07:26 PM
RA031524
Canada
Sep 10, 2007 12:07 PM
dagg
Jun 18, 2004 07:35 PM
