How to reset check engine light
Old Aug 17, 2012 | 01:29 AM
PaulaMae94's Avatar
I have a 06 Infiniti g35 coupe. My camshaft position sensor in bank 1 went bad. I replaced it but the check engine light is still on. How can I reset it? Also, I figured this was from the bad sensor but not sure. Sometimes when I was driving the car would stall, like it was in neutral for a few seconds, then it would say slip and be fine. Any ideas why? I've read where it could be brakes... I do need new brakes soon.
Old Aug 17, 2012 | 01:39 AM
My Key's Avatar
Not sure about the stalling but as for resetting the SES, I pulled the battery, pumped the brakes and reconnected the battery and the light disappeared
Old Aug 17, 2012 | 02:01 AM
seymore4's Avatar
m56
If you stop by any major autoparts store they will let you use a scan tool for free, clear the codes and see how it runs
Old Aug 17, 2012 | 01:08 PM
lostangels01's Avatar
Sorry to burst your bubble, but its best to replace both camshaft sensors instead of one. Also, doing the pedal ECU reset procedure will help with the CEL.
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
