[Help] New G35 Owner Best Mods and Upgrades
Old Feb 1, 2019 | 12:14 PM
IS44C's Avatar
G35x Sedan 4DR AWD
I've been doing a lot of research and reading over tons of information on this forum and need to know if this is a good parts list as of right now. Any advice or tips is highly appreciated!
(I do have a Magnaflow 14815 Exhaust came with the vehicle when I purchased it do to stock exhaust rusted out)
List:
Stillen Hi-Flow Intake Kit with Z-Tube
MotorDyne spacer/MREV2
NGK Iridium IX Plugs
Stillen Headers
Stillen Cats
Spec-D Grille
Spec-D OEM Headlights
TSW Crowthrone Rims
Bilstein Suspension
Turbonetics Single Turbo
Old Feb 1, 2019 | 01:21 PM
fitgineer_93's Avatar
What year, and how many km?
That's quite the overhaul for a "daily" driver. Best of luck.
Old Feb 1, 2019 | 01:33 PM
cswlightning's Avatar
If you did your research you'd know what it takes to have a reliable turbo G35... that last one there should also include a $7000 engine rebuild and even then it's not a car I'd feel comfortably dailying.... Might as well swap an LS especially if you want it to last 100k+ miles.
Old Feb 1, 2019 | 01:37 PM
IS44C's Avatar
G35x Sedan 4DR AWD
2004 and 123k
Old Feb 1, 2019 | 01:40 PM
IS44C's Avatar
G35x Sedan 4DR AWD
Have not read a lot on turbos. Read somewhere it was a great single turbo for daily drivers.
Old Feb 1, 2019 | 02:01 PM
There's a reason you don't see many turbo VQ35DEs and the reason for that is a combination of high cost, low power output, and below average lifespan.
Old Feb 1, 2019 | 02:11 PM
IS44C's Avatar
G35x Sedan 4DR AWD
Good to know, thank you for the information. Anything else on the list you might change?
Old Feb 1, 2019 | 03:10 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Just do the typical bolt-ons and a tune. Should make an extra 35-40 hp or so, make the car more fun to drive. Then do the Hotchkis anti-roll bars and 350Z springs and struts. Tightens up the suspension and gives a very street-able 1" drop. If you want big power improvements, like already suggested, do an LS swap. Way more room in the engine bay for a turbo or supercharger too. Buddy of mine has one, cam. headers, some head work. Makes 480 hp at the wheels.
Old Feb 1, 2019 | 03:55 PM
Yeah if you've got the money to burn on a G35 changing out every single bushing to polyurethane should make a huge difference in the way the car drives since all the stock bushings are worn out on age alone at this point. You didn't mention 6MT or auto, but for an auto TransGo shift kit, for a 6MT either do the RJM clutch pedal ($$$) or delete the clutch assist spring in the stock assy (free, takes an hour)
Also if your daily drive involves nighttime and you like to go fast at night better headlights than those Chinese ones would be nice. If you've got money to burn either get a retrofit or clean up a set of 06 projectors
The Shadow
Sep 2, 2017 09:26 AM
Jarred1997
Nov 12, 2012 01:37 AM
SFLG35
Florida G Club
29
Jun 10, 2005 09:54 PM
2fast
Sep 11, 2003 04:29 PM
