04 g35x sedan vibration
Old Mar 14, 2019 | 12:33 AM
Alvaro555's Avatar
Clean g35x
Im having a problem with my front wheels its starts vibrating at about 30mph i dont think its the tires they’re in good condition, and no wear or tare on them. Its a type of vibration where it just sounds weird and my steering wheel doesnt shake a lot. Any suggestions would help, thanks!
Old Mar 14, 2019 | 12:54 AM
fitgineer_93's Avatar
pm'd you.
Old Mar 14, 2019 | 08:51 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Might have the balance checked on your front wheels. I had that problem when I bought my 05' and it cost a whole $5 to fix - It would be fine until 35-40 mph then get rough.
Old Mar 14, 2019 | 09:45 AM
cswlightning's Avatar
If it was the front wheels you'd be getting steering vibrations I'm thinking. Are you 100% it's the speed, not the engine RPMs?
Old Mar 16, 2019 | 01:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Start by checking to make sure all your wheel lugs are torqued properly.
Then get those tires balanced.
If it's still persistent due to vehicle speed then look into other rotating components like the propeller shaft u-joints and such.
If it's a vibrating that's only persistent while BRAKING then it's usually just a warped rotor.
If it's vibrating due to ENGINE RPM then look into the engine mounts and other powertrain mounting.
Old Apr 30, 2019 | 09:46 PM
IS44C's Avatar
G35x Sedan 4DR AWD
Check your CV boots and look for any damage or tears. This could be the answer to your problems. As there is no grease for the axle and there is water entering through.
Fire0nic3
Feb 28, 2017 11:31 PM
withinsight
Aug 14, 2014 12:18 AM
TSalzNC
Aug 3, 2013 09:39 PM
RLampke
Sep 13, 2005 07:24 AM
Stan Vaddi
Mar 28, 2005 02:03 PM
