Different/modded air box?
Old Mar 31, 2019 | 02:15 PM
05_Blue_G35's Avatar
Changing the air filter is a PITA with the design of the stock air box. Are there any aftermarket air boxes/intakes that use the paper filter or mods for the stock air box? Looking for something that just makes changing the paper filter simple and quick. I don't really care about performance/CAI type stuff, though that may be all that's available...
Old Mar 31, 2019 | 02:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Try taking it off as a single unit, unbolt it from the throttle body, unplug the MAF, remove the single support screw near the MAF, unbolt the filter housing and take it all out as one piece.
Honestly though I don't think it's that bad to replace the filter in these cars compared to some vehicles on the road.
Old Mar 31, 2019 | 09:29 PM
Blue Dream's Avatar
I drove ttrank's car solo
OP seriously? It takes 5 minutes to pull the box, replace the filter and re-install the box. Wow, just wow if this is the direction the forum is headed in the future. I haz the sadnezz.
Old Mar 31, 2019 | 09:58 PM
Yeah I'm serious. It takes more than five minutes to pull the box out. It SHOULD only take five minutes to swap out an air filter. I've got other more important sh*t to spend my time on...
Old Apr 1, 2019 | 12:44 AM
IS44C's Avatar
G35x Sedan 4DR AWD
Just drop a couple hundred on a CIA then you wont have to worry about taking it apart
Old Apr 1, 2019 | 01:49 AM
Scorpi0's Avatar
Remove the filter completely.... Moar Powaaaaa!!!!!!
Old Apr 1, 2019 | 08:31 AM
Blue Dream's Avatar
Then you're doing it wrong.
Old Apr 1, 2019 | 11:06 AM
MooseLucifer's Avatar
5 Year Member
blk
OP, I'm not trying to be an ***, but how much is your time worth that you can't be bothered to spend a few extra minutes changing a filter? If your time really is that valuable, then call a mobile mechanic and pay them to change it for you.
In my opinion, a slightly harder-to-change filter is well worth the trade-off of having a well designed, efficient intake.
Regardless let's run the numbers. We'll assume your time is extremely valuable at $100 per hour.
If this new airbox you find saves 4 minutes in filter change time but costs $120, it'll take 18 filter changes to make up the cost of that intake. If you change your paper filter every 10k miles, well before the standard recommended interval (15-30k), that's 180,000 miles before you make up the cost of that intake. This is all before mentioning that your new design will likely be less efficient, reducing your fuel economy if you stretch the legs of that glorious VQ every once in a while.
Save your money, pick a new battle.
AaronDrama4280
Picture Share
39
Feb 5, 2013 06:16 PM
jonavalos93
Intake & Exhaust
Jan 18, 2013 11:53 PM
some.devil
Apr 5, 2006 08:57 AM
court
Sep 1, 2004 04:13 PM
Tory
Intake & Exhaust
Dec 26, 2003 05:41 AM
