Oil Recommendation for when GC is not available
Old May 27, 2019 | 11:14 AM
MaxChlan's Avatar
Infiniti G35 Sedan 6mt; 1986 Nissan 720 4x4
Oil change with VR1 is complete. We'll see how it burns. Not enough oil came out when I did the oil change, so obviously I am burning oil. I hope the rings aren't totally ****ed.
**Edit: this forum automatically censors swearing? Interesting.
Old May 28, 2019 | 11:22 PM
Urbanengineer's Avatar
No swears!
Old May 28, 2019 | 11:49 PM
MaxChlan's Avatar
Originally Posted by urbanengineer
no swears!
Old Jun 5, 2019 | 05:37 PM
LoSt180's Avatar
Take it from someone who has 281k miles on his 06 6MT and has plenty of time to test different options. Stay out of the what oil is best threads, it doesn't matter at all if you're consuming oil. Slow the burn rate by going to a thicker oil, 10w-30 is enough. Also start running the larger oil filter from Nissan V8 engines (Armada/Titan) it bolts right on.
Then just start running whatever oil is having a special. I used to stick with Castrol GTX, but recently said screw it and bought 2 cases of Amazon oil.
Old Jun 5, 2019 | 08:01 PM
cswlightning's Avatar
You must be LOST, you're in a what's oil is best thread right now
I've been using 10w-40 high mileage dino oil since I bought the car, seems to keep burn rate steady and no worsening of my spark plug gasket thingy leak after 30k miles. As usual cleric you taught me something about the high mileage designation allowed to be an older spec less compromised by environmentalist red tape.
Cleric, why do you suggest the spacer for me in particular? Is it the fact I track my car, or the fact that my car topped out at 140 MPH this morning and I NEED NOS?
Old Jun 5, 2019 | 08:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's just information that's hard to find, all I'm doing is shining a light on it so you guys can do your own research.
Crankcase capacity is ALWAYS a good thing, especially when you're pushing the car hard, and MORE ESPECIALLY on an engine that can suck quite a bit of oil on a hard track day. One of the biggest reasons diesel motor lasts so long is because they hold 4 gallons of oil in the crankcase compared to the 1 gallon you find in a gasoline engine (the other reason being the rings are lubricated from both sides of the piston since diesel is an OIL).
Old Jun 6, 2019 | 01:41 PM
MaxChlan's Avatar
To this point, I have been burning less oil with the VR1 10w-30; a little over 1000 miles since the last change and I've burned about 1/2 a quart, down from I don't even know how much with the Royal Purple 5w-30 because I wasn't checking the oil *properly*, but I can say it was over 4 quarts over the life of the oil change. I check the oil every morning before I leave now.
Old Jun 6, 2019 | 04:09 PM
Pbfoot's Avatar
04 G35 Sedan performance package. 70k Eibach springs and sway bars. 19 inch wheels. Plenum spacer.
I used the larger Mobil 1 oil filter with Mobil 1 10/30 high mileage last oil change. I am at 3375 miles and the oil level is in the middle of the range right where it was when I changed it. Previous oil change was with regular 10/30 Mobil 1 and a Fram filter. I was using 1/2 a quart every 1000 miles. I'm a believer. Thanks Cleric.
Old Jun 12, 2019 | 01:29 AM
Thanks for popping your head in lost. Always excited to see you high mileage G coupe that matches mine in color stick around.
Railgunner
Sep 15, 2006 09:05 AM
Geez4me
May 11, 2006 06:04 PM
