What is wrong with my g35
Old Jul 17, 2019 | 03:11 PM
JacobEllis's Avatar
g35 sedan
I have a 2003 g35 that i recently replaced both cam position sensors. But today a familiar problem came back when i was pulling on to my street and the car just shut off. Now the car won’t start. Yes i have gas, oil, and all the lights on the dash come on along with clicks when i turn the car on. Anyone have an idea of what my problem could be?
Old Jul 17, 2019 | 03:14 PM
Scorpi0's Avatar
Does the engine crank when u try to start it? Did u use OEM camshaft sensors?
Old Jul 17, 2019 | 03:16 PM
JacobEllis's Avatar
g35 sedan
yes it cranks and yes i did
Old Jul 17, 2019 | 04:53 PM
Scorpi0's Avatar
Could be the crankshaft position sensor now.
Is the check engine light on? Any codes?
Old Jul 17, 2019 | 09:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
While cranking the engine see if the tachometer moves, if it does NOT then your crank sensor probably failed.
Old Jul 17, 2019 | 09:23 PM
cleric670's Avatar
BANNED!!!
And just to verify that you DO have gas, you put a fresh gallon into the tank correct? Or you are tracking your mileage via miles driven. The fuel gauge is notorious for failing and showing a half tank when you're actually empty.
Golfer622
Apr 2, 2012 06:11 PM
Omi
Florida G Club
20
Jan 8, 2008 11:23 AM
