2004 g35x need part number for front left marker light bracket
Old Sep 21, 2019 | 08:21 AM
jzanone's Avatar
As in the subject line, my front left marker light suddenly came off. It appears the bracket behind it is completely rusted out (thanks NJ winters!). I've tried all of the Infiniti parts sites but can't seem to identify what the part number is for the bracket, if there even is an actual bracket. Any help is greatly appreciated.
Thanks,
John
Old Sep 21, 2019 | 10:15 AM
G2B35AGN's Avatar
There is no bracket. It simply clips in after plugging the wire into the socket. Tug on the opposite side that's still there. You'll see the metal spring clip. The clip comes with the marker; not a separate part.
Is this the orange OEM or a JDM clear corner? OEM orange should be easy to find. JDM clears for a sedan are unicorns.
Old Sep 21, 2019 | 01:59 PM
jzanone's Avatar
Hi, thanks for the reply. You are correct in that the marker clips in. However, I need the part it clips in to as mine is completely rusted out. I think I was able to find the part. It appears to be the bumper mounting bracket 62223-AL500. It appears to screw into the fender above it but also appears to be riveted to the bumper itself. I've ordered the part but I'll have to figure out a way to secure it to the bumper, although that may not be necessary if the bracket is bolted to the fender.
I keep having to replace rusted out items. Maybe it's time to let the car go, although it still runs very strong at 180,000. Starts right up, pulls strong, uses NO oil. Just getting a little tired of replacing items.
John
Old Jun 12, 2021 | 05:20 PM
miamichillin99's Avatar
John
Hi,
I'm having the same rust issue. How did you attach the bracket? Was the part number that one? It appears to be so. 62222 is the right and 62223 is the left.
https://parts.pepeinfiniti.com/p/INF...222-AL500.html
SelmSiccTwo
Dec 18, 2018 08:57 PM
Gator87
Nov 29, 2018 07:17 AM
matdaddy
Lighting
Nov 20, 2012 05:00 AM
G35sti187
Archived Sales
Apr 1, 2009 12:27 AM
