Had the slip light on my 2005 G35 infinity four door sedan along with the abs light
Old Sep 21, 2019 | 02:43 PM
Babyblue35's Avatar
2005 3.2liter v6 g35coupe
Recently I just got my g thirty five sedan off my dad well we both drive it well anyways there where a few mayor problems at 160000 miles I change my oil since I know this car burns oil i did the trick where you plug up your engine and install a breather filter Been helping I haven't had to put and oil it Also had to replace left ballast for the headlight it wasn't working we usually order our parts off of Amazon now I'm all about just finding a same exact car and change the parts if you can have some technicaian install it your parts if there electronic if there to hard and your not a machanic don't try
Old Sep 22, 2019 | 12:01 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Do you also have a check engine light? You need to see if you have any active or pending engine codes to help narrow down the possibilities.
Old Sep 22, 2019 | 12:05 AM
Babyblue35's Avatar
It was something else
Naw man it was the clock spring just replaced it and had a technician reset the traction and abs and it works perfect now easy fix oh of course he has to set the steering angle he should know what there doing I went to a Infinity lot that works with infinity's not a dealership lucky the guy working on my car worked at Infinity thank you God no more slip abs and slip lights!!!!! Should also fix abs lock up at 10 mph also brake light with battery light mean a bad alternater had to replace that too air was cutting in and out take car of your engines there nice engines mine purrs like a kitten
Old Sep 23, 2019 | 02:24 PM
Babyblue35's Avatar
Recall
Hey that air bag thing everyone gots infinity had a recall just see if your G35 is a part of that recall my was going to take it into the dealership and get it fixed I'll let your know I'ma take it in a week
Old Sep 25, 2019 | 08:31 PM
Blue Dream's Avatar
I drove ttrank's car solo
Baby your posts are too painful to read. Talk about a run-on everything.
Oh another thing: infinity- a concept describing something without any bound, or something larger than any natural number.
Infiniti-Japanese automobile manufacturer
Old Sep 25, 2019 | 08:39 PM
Babyblue35's Avatar
Clock spring
I had my ABS vcd light on along with my slip light on.Also had a lower control arm problem with a worn-out bushing. I had a broken ballast. I had a broken motor sunroof motor.I have a bad fuel pump.The fuel pump reads 3/4 away full. I sense worked on all issues. The vcd light slip ABS light was the biggest issue I had.I found out it to be a clock spring problem.Along with the ABS light the SRS light came on or airbag light. I found salvage yard next to my house in Phoenix. It had about I 10 to 20 used infinitis and a couple of z 350 if you guys know about those. We ended up getting the clockspring off one of the used infinitis and simply replaced it and reset the traction control.AlI I did was the 7-second 3 seconds off trick and it did take off all my lights. So I recommend doing that. Also there is the fuel gauge problem. I've been looking into that and I also switched out that. I cleaned the connectors and it works somewhat but not totally fixed.I also replaced the ballast on the car too. It got wet from wet sanding the light. If any of this happened to if you or, you have any questions about what I did or,if you have any similar problems you can reply me back and I will be happy to walk you through it. I also did a modification on the PCV valve or I installed a breather filter on there and plugged up the a port in the engine and it's working fine and consuming less oil if you need any if you have any questions please feel free to reply back and I reply back as soon as possible thank you I have g 35 driver
Old Sep 25, 2019 | 11:04 PM
fitgineer_93's Avatar
Punctuation.
Old Oct 5, 2019 | 11:44 AM
Blue Dream's Avatar
TLDR, sorry.....
terrym12
Jul 22, 2021 08:16 PM
Salman
Dec 23, 2018 11:50 AM
Graceismylizard
Nov 13, 2012 01:33 PM
6MT G-STYLE
Team 210 VQ'Z
Jun 8, 2007 11:03 PM
