Seat doesnt move on exit or enter
Old Dec 11, 2019 | 01:54 AM
espifrankie's Avatar
G35x
I had to change my battery and alternator and everything seems to be okay now, except that my driver seat does not slide back on exit or start anymore. I tried the memory reset procedure and still nothing. its unsatisfying right now getting out of the car in the normal position. please help.
Old Dec 11, 2019 | 10:03 AM
05_SkylineSedan's Avatar
20 Year Member
From the owner's manual ('13 G):
Initialize entry/exit function
If the battery cable is disconnected, or if the fuse opens, the entry/exit function will not work though this function was set on before. In such a case, after connecting the battery or replacing with a new fuse, open and close the driver’s door more than two times after the ignition switch is turned from the ON position to the LOCK position. The entry/exit function will be activated.
John Kosturik
Feb 26, 2018 09:06 PM
Just1Question
Mar 24, 2016 02:44 PM
kayveeee
May 4, 2011 01:40 AM
delsap
Nov 29, 2010 07:30 PM
davidology
Sep 15, 2005 10:48 PM
