04 G35 Overheating
Old Dec 17, 2019 | 11:28 PM
KevSil616's Avatar
Cream White / Standard
04 G35 Overheating
Ok so about Thursday of last week on the way to work my G35 Temperature gauge starting going up. Pulled over immediately and called a tow. Once I made it home I checked my coolant level which was completely dry. Refilled with some new coolant, made sure the air was out and took the car around the block a few times and the temperature gauge started climbing again after a while. Decided to leave the car alone and waited for Friday. Checked the coolant levels which did not seem to have decreased. So I'm not thinking it is a coolant leak. Decided to check the fans which I noticed then that they didn't seem to be running (although it could've been that I hadn't noticed them kicking on or giving them the chance to) I checked the fuses and relays. Decided to do another test drive and this time I noticed that the fans were running. This time the temperature gauge didn't climb up and I thought the car was fine. That was until Monday. Did some driving all day then by the end of the day thr temperature gauge started climbing up again. I've been looking at the car all day today. Fans are running fine. No coolant loss that I can see. I thought maybe the thermostat is bad, but coolant does seem to be circulating as I can feel the upper radiator hose is filling up so I'm assuming it is circulating. I tried to see if anymore air was in the system that may have been missed the first time. I'm literally at my wits end right now. If anyone has any ideas of what this could be. Please lmk. Thanks so much!
Old Dec 18, 2019 | 08:28 AM
eazdaskeez's Avatar
Did you check the lower hose? It should get hot as the car reaches operating temp.
Old Dec 18, 2019 | 08:57 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If your thermostat stays closed it will get too hot rise above normal and overheat, if it stays open it won't get hot enough in the colder months for cabin heat. If you aren't loosing any coolant I would probably change the thermostat out since it's only a $20 part. They do fail, mine went out at 128k miles.
Old Dec 18, 2019 | 09:05 AM
KevSil616's Avatar
just checked it this morning and no it doesn't seem to be getting hot
Old Dec 18, 2019 | 09:08 AM
KevSil616's Avatar
yes I was thinking of it being the thermostat except those 2 days that I was able to drive with no issues kind of put me at a loss and those were about an hour drive each way
Old Dec 18, 2019 | 09:54 AM
eazdaskeez's Avatar
Change the thermostat, should fix the issue. A cold lower hose is a clear symptom of a failing thermostat
Old Dec 18, 2019 | 10:28 AM
KevSil616's Avatar
thanks I'll do that and see if that works
Old Dec 23, 2019 | 06:53 PM
KevSil616's Avatar
well went ahead changed out the thermostat after bleeding the system. Put in new coolant made sure I got all the air out. Tested the system. Lower radiator hose was heating up and then tonight same thing again. Car started overheating and lower radiator hose was not heating up again.
Old Dec 23, 2019 | 07:13 PM
eazdaskeez's Avatar
Gotta ask, was the thermostat oem? Or aftermarket? Many stories of thermostats not working right out the box if they are aftermarket.
Old Dec 23, 2019 | 07:15 PM
KevSil616's Avatar
it was an aftermarket from motorcraft one that I got from Autozone.
Old Dec 23, 2019 | 07:18 PM
eazdaskeez's Avatar
I would honestly get and oem one. Then go to the next troubleshooting step which might be a complete radiator flush
Old Dec 23, 2019 | 07:21 PM
KevSil616's Avatar
I went ahead and did a flush when I put in the new thermostat. Do you know where I'd be able to purchase an OEM thermostat? Also noticing that the reservoir tank is filling up more as well
Old Dec 23, 2019 | 07:25 PM
eazdaskeez's Avatar
Oem from the dealership, should be 30 bucks or so. Is the reservoir filling up after the car reaches operating temp?
Old Dec 23, 2019 | 07:27 PM
KevSil616's Avatar
Yes, it's filling up after reaching operating temp
Old Dec 23, 2019 | 07:31 PM
eazdaskeez's Avatar
Well that's nomal because coolant expands when it's hot so that's what the reservoir is for. To catch the expanding coolant that the radiator can't hold. Once it cools down the reservoir will get lower as the radiator sucks coolant back into itself.
