Finished installing some bolt-ons, ops?
Old Feb 14, 2020 | 02:36 PM
janderson's Avatar
Infiniti G35x Sedan
Recently installed Z1 hfcs, Z1 z-tube w/jwt pop charger, and Z1 5/16 plenum spacer.
The previous owner also put on a flo-pro muffler (not sure why) w/ a magnaflow midpipe.
Here's a sound clip. Btw any suggestions on coilovers for the g35x? It's an 06'
http
Old Feb 15, 2020 | 12:03 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
If you want to drop it on the cheap, 350 springs and struts give a 1" drop and an OEM ride. As far as coilovers, stay away from the cheapie offbrand eBay stuff and you should be fine.
Old Feb 15, 2020 | 12:44 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you get the 350Z springs just make sure they're the revised ones. Nissan uses color coded dots on the spring to identify them, there's a thread somewhere around about which ones are the revised.
Old Feb 15, 2020 | 08:19 PM
janderson's Avatar
Infiniti G35x Sedan
Gotchya, forgot to mention I have an X, and I heard that dropping on springs on an X is hard on the AWD components, but I was leaning towards Truhart or Megan Racing coils. Will look more into getting Z struts and springs tho, thanks for your ops
Old Feb 17, 2020 | 11:23 AM
srv2nv's Avatar
G35 Sport
Double check the intake/MAF with the AC line and make sure it's not touching or rubbing. Common issue with the ztube/popcharger
Old Feb 18, 2020 | 08:15 AM
janderson's Avatar
Infiniti G35x Sedan
gotchya, will do
nopama
Sep 12, 2009 06:57 AM
Motown_Hog
Mar 17, 2006 08:42 PM
Strtsk8r321
Intake & Exhaust
24
Mar 4, 2006 11:24 PM
ashadiow
Apr 22, 2005 02:35 PM
