Valve cover bolt broke
Old May 31, 2020 | 07:59 PM
Ayebro's Avatar
infiniti g35x stock with 162k miles
Currently, I have a valve oil leak. I went to check the bolts to make sure they were tightened enough. To my surprise, when I started tightening one of the bolts...it broke. I would say 75% of the bolt is stuck in there. I'm planning on using an extractor and replacing the valve covers and gaskets. Does anyone
have any tips or advice? So far, I am going to have someone holding a vacuum to it so I make sure to control the debris from the drill.
Old Jun 1, 2020 | 09:50 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Old Jun 1, 2020 | 04:05 PM
johndom450's Avatar
Which bolt is it that broke? I broke an outside driver's side one while doing mine. It wasn't very accessible, and I wound up breaking the small extractor I was using inside of it. Once one of those breaks, it is next to impossible to drill out the hard tool steel they are made of. If you have access to the spot, I might suggest drilling it out (a 90 degree drill helps) and using a Heli-coil insert to avoid this problem.
Ultimately, I wound up using a small C clamp over the outside of the valve cover and some extra RTV in that area. No leaks for the past 15k miles. I just used some superglue in the C-clamp threads so that it wouldn't come loose with vibration. Torque specs for these are only a few foot pounds, and even slightly over that will snap them easy unfortunately.
Old Jun 2, 2020 | 02:30 PM
haynV35's Avatar
White G35 Sedan
Sorry, have no guidance to offer for extraction.
but just curious, did you tighten it with a regular socket wrench? or an in/lb torque wrench?
Old Jun 5, 2020 | 10:23 PM
Ayebro's Avatar
Regular socket wrench.
Old Jun 5, 2020 | 10:24 PM
Ayebro's Avatar
Update: I had the bolt extracted with a drill bit and the new bolt thankfully picked up the thread.
Old Jun 10, 2020 | 07:09 PM
haynV35's Avatar
White G35 Sedan
good to hear
next time you should invest in an in/lb torque wrench and look up the specs. the bolts will have no trouble penetrating the aluminum cast, and even a small socket wrench can easily over torque it. i believe people said you can use a screwdriver with a socket adapter (think theres a specific name for the tool) and do it by hand with that, but i got an in/lb torque wrench from oreillys to make sure they were to spec
DumpsterJedi
Oct 1, 2018 11:44 PM
eCryptiic
May 3, 2018 08:15 PM
Daarkness
Jun 22, 2011 01:23 AM
Andrei
21
Apr 8, 2011 12:59 AM
si_driver
Sep 25, 2010 11:53 AM
