'04 6MT partial restore..
Old Oct 19, 2020 | 11:09 AM
c0yl3_'s Avatar
Aloha,
This has been a fun corona project for the last couple of months.. Going well!
So far..
-full engine disassembly
-new rings
-new bearings
-new valve guides
-both subframes out(front replaced with new due to collision damage)
-kybs on all corners
-energy master set
-full de-crusting and some replacement metal(rockers, rear trunk support channels, etc)
-gas tank out for minor fixes
-fresh CD00A from Infiniti
Everything on the outside of the car has been touched but I am curious if I need to replace the rear "floor pan reinforcement" structure. It was absolutely crustified and came out in two pieces when I originally removed it.
Do I need it?
​​​​Thanks!
Pics incoming.
Old Oct 19, 2020 | 03:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah you should replace it, source a used one from eBay or something. Take it and coat it in either undercarriage spray, or truck bed liner, or something (urethane based preferrably). It flexes a lot and cracks the paint at every joint, then it rusts out at those points. Without the rear stay brace your chassis will flex more.
Old Oct 19, 2020 | 03:30 PM
c0yl3_'s Avatar
Understandable, i figured it failed due to salt collection (Canadian winters).
The car is summer only now.
Old Oct 19, 2020 | 03:37 PM
c0yl3_'s Avatar
Would this suffice in its place? My subframe connectors are almost junk.
https://ultraracing-usa.com/infiniti...rame-4-points/
Geniusjustin
May 27, 2008 01:23 PM
shdowflare
Jul 28, 2007 07:48 PM
Kilrmy
May 12, 2003 09:29 PM
